Results 1 to 4 of 4
  1. #1
    Gold Member
    Join Date
    Feb 2010
    Posts
    368
    WNY, USA
    Default 4300 alternator output
    it appears that the 4300 has a 40 amp alternator. does anyone know how much of that is used when running? running + lights? if not, i'll have to put my amp meter on it and see...just thought someone here may already know and save me the trouble.
    curious, because i added an original tractor cab this year, and was looking at some electric 12v heaters. one draws 25 amps, which i'm sure is at full power and would have blower/heat settings for variable output. i saw a smaller one, but am still looking for specs on it.
    just wondering how many amps were left over to play with.
    thanks.
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,767
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: 4300 alternator output
    I'm curious to know how you would sort it out using the amp meter.
    Load it somehow and find out when it goes to discharging the battery?
  3. #3
    Gold Member
    Join Date
    Feb 2010
    Posts
    368
    WNY, USA
    i'm not sure either. i have a DC clamp on. i figure if i put it on the battery cable, i can see the amp flow. at initial startup, i figure is when the battery is drawing the most amps. turn on the headlights, it should change? or for the lights, i can put it on the individual light wire and see what they draw. i know i have 40 to work with.
  4. #4
    Gold Member
    Join Date
    Feb 2010
    Posts
    368
    WNY, USA
    come to think of it, my clamp on meter has AC and DC amps...if i can find a single AC conductor coming from the alternator (should be 3 wires?), i could tell what is coming out of it. but not sure i will be able to find one as they are probably wrapped in a sheath of some sort.
    what else is electric? battery charging, lights, fuel pump/solenoid?
Similar Threads
  1. height of 4300 rollbar - fixed vs foldable
    By defed in forum John Deere Owning/Operating
    Last Post: 07-11-2011, 08:26 PM
  2. Need help deciding.. JD 1050 or JD 4300?
    By sweetjeep in forum John Deere Buying/Pricing
    Last Post: 06-27-2006, 11:12 AM
  3. used 4300 info please
    By ChrisNJ in forum John Deere Buying/Pricing
    Last Post: 06-08-2002, 11:11 PM
  4. Price Check 4300 Pricing in NE
    By sleepyhollow in forum John Deere Buying/Pricing
    Last Post: 08-08-2001, 06:32 PM
  5. 4300 VS 3010, UP IN THE AIR
    By Anonymous Poster in forum Kubota Buying/Pricing
    Last Post: 06-28-2001, 08:38 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
