Results 1 to 9 of 9
  1. #1
    Member
    Join Date
    Jun 2011
    Posts
    25
    Default 1020 head gasket problem
    I'm reposting this from the repair section
    I noticed that my JD 1020 coolant is always about 1 gallon low.
    So I tried filling it up, but then started getting a lot of smoke out of the blowby tube (or whatever it's called).
    I also noticed that my freshly changed oil had water in it.
    So what I'm thinking is that the head gasket is leaking and coolant is getting into the crankcase.
    A few questions:
    Does this sound like a head gasket leak?
    How difficult is that to change out on a JD 1020?
    How long can I get away with putting the job off? I run the tractor for maybe 20 hours / year just to maintain my hunting property and put in food plots.
    Thanks in advance.
    PS - Diesel, about 7,000 hours.
  2. #2
    Silver Member qstott's Avatar
    Join Date
    Jan 2006
    Posts
    196
    Elm City, NC
    '65 110 JD, 445 JD, 4720CabJD
    Default Re: 1020 head gasket problem
    Gas or desiel?
  3. #3
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Coolant in the crank oil is not good.
    Hope that it isn't a cracked block and is only a head gasket.
    I'd try some radiator stop leak on the chance that a crack is small and that puts a stop to the leaking. But wouldn't count on it working. Just that if it does, then you have prolonged the inevitable search and repair of the problem.
    Good luck.
  4. #4
    Member
    Join Date
    Jun 2011
    Posts
    25
    Quote Originally Posted by qstott View Post
    Gas or desiel?
    Diesel. Sorry.
  5. #5
    Member
    Join Date
    Jun 2011
    Posts
    25
    Quote Originally Posted by beenthere View Post
    Good luck.
    Good idea. Thanks.
  6. #6
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Do it as soon as possible. Coolant is heavier than oil and will settle in the bottom of oil pan. Eventually, if you have enough coolant in the pan you will start it up and the oil pump pickup will suck the coolant before it gets to the oil. Then it will be to late.
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
  7. #7
    Join Date
    Jan 2006
    Posts
    196
    Elm City, NC
    I don't know if the engines are similar, but I replaced the head gasket on my JD1050. I had a Yanmar 3 cyl turbo engine. It was fairly simple. I sprayed the exhaust manifold bolts once or twice a day with PB blaster for a week ahead of time. I took it apart, laying out parts in the order they came off. The thing you don't want to overlook is, be sure to check the flatness of the head before you reinstall it. I used a real straight edge and a feeler gauge. I had less than .002" gap at any spot. Tightening sequence and head bolt torque are very important also. The stop leak that the previous owner had put in it made things a bit messy. I'd stay away from that if you plan to do it anytime soon.
  8. #8
    Join Date
    Jan 2007
    Posts
    1,913
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Figato
    If you remove rad cap while engine is cold and start engine do you see bubbles in coolant in rad?? Coolant leak could also be a pin hole in a cyl liner from debris in coolant hitting liner or bad coolant PH. Coolant loss needs to be repaired as anti-freeze is death to rod/main brgs.
  9. #9
    New Member
    Join Date
    Aug 2012
    Posts
    1
    Lebanon Ohio
    1050 John Deere
    How do i replace a head gasket on my 1050 John deere diesel tractor
Similar Threads
  1. JD 1020 head gasket leak - questions
    By Figato in forum Parts/Repairs
    Last Post: 07-15-2012, 05:52 PM
  2. Massey head gasket leak?
    By Cascadia Farmer in forum Parts/Repairs
    Last Post: 12-22-2009, 06:11 PM
  3. Ford 1710 Head Gasket Replacement ????
    By asylum in forum New Holland Owning/Operating
    Last Post: 09-15-2008, 10:36 AM
  4. 1610 head gasket issue
    By Box in forum Yanmar
    Last Post: 07-09-2007, 05:39 PM
  5. 23HP B&S Head Gasket Problems?
    By MBDiagMan in forum Cub Cadet Yanmar & CUTs
    Last Post: 08-14-2005, 07:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
