Results 1 to 8 of 8
  1. #1
    Bronze Member Bubba Tex's Avatar
    Join Date
    Apr 2007
    Posts
    55
    Boerne, TX
    JD 2305
    Default 2305 won't stay running
    My 2305 with 104.5 hours on it won't stay running when I move the drive selector from Neutral or when I engage the PTO. It starts, idles and runs well through the rev range and I can operate the loader.
    I have tested the seat safety switch and it seems fine, and, just to be safe I jumped across the connector...no love.
    Fuel is full, hydraulic oil level is fine.
    Any ideas?
    Be the river, Baby!
  2. #2
    Join Date
    Dec 2008
    Posts
    1,622
    Up-State New York
    Grand L 3540 HST-3, R4's
    Default Re: 2305 won't stay running
    If it runs when standing still but shuts down when you try and move it, has to be a safety switch. Either seat or PTO, check again.
    DevilDog
    He is your Friend, Your Partner, Your Defender, Your Dog. You Are His Life, His Love, His Leader. He Will Be Yours, Faithful And True, To The Last Beat Of His Heart. ...Unknown
  3. #3
    Join Date
    Apr 2007
    Posts
    55
    Boerne, TX
    JD 2305
    Where is the pto safety switch?
    Be the river, Baby!
  4. #4
    Gold Member smalltown's Avatar
    Join Date
    Jan 2011
    Posts
    421
    Western Maine
    2011, JD 2520
    Bubba how about water in the fuel or the fuel filter?
    62D MMM, 200CX loader, iMatch Quick Hitch, Ballast Box, #46 Backhoe
  5. #5
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,739
    Bedford, VA
    John Deere 2320
    Based on what you are saying it must be the seat safety switch.. Without your butt in the seat you cant move out of Neutral or engage the PTO or it shuts down..
    It thinks someone is not in the seat and doing what it is suppose to do..
    to run the PTO you have to be in the seat (or it has to sense someone in the seat) and the parking brake must be set..
    Since it runs otherwise it cant be fuel..
    b
    Bedford, VA
    2320 w/ 62D MMM, 200CX FEL, Pats EZ Change, LX4 Cutter
    Co-owner (with my father) of John Deere 790, 30 HP, 4x4, 513 cutter, 70 FEL
    2012 Nissan Xterra Pro-4x
  6. #6
    Join Date
    Apr 2007
    Posts
    55
    Boerne, TX
    JD 2305
    I don't think it would run well at all if it were a fuel issue.
    Is there a separate safety switch for the PTO?
    Be the river, Baby!
  7. #7
    Join Date
    Dec 2008
    Posts
    1,622
    Up-State New York
    Quote Originally Posted by Bubba Tex View Post
    Just make sure it is not engaged, that will cause it to shut down. Try this sit on seat as normal and start tractor, now get off seat and stand to side of tractor and slowly press down on HST petal with your hand ( Slowly and make sure you are not in front of tire so you don't get run over) tractor should shut off. If it does this double check for seat safety switch they can be very sensitive.
    DevilDog
  8. #8
    Elite Member
    Join Date
    Mar 2005
    Posts
    2,739
    Bedford, VA
    John Deere 2320
    Quote Originally Posted by devildog1 View Post
    DevilDog
    I dont think my 2320 will shut down by pressing down on the HST pedal as you describe. i know that I have started the tractor, set the parking brake and started the rear pto - then got out of the seat and pushed on the HST pedals and it stayed running.
    With mine, sit in the seat, start the tractor.. As long as the gear selector stays in Neutral you can get out of the seat and it will stay running. IF you put it in gear and get off the seat it shuts down immediately.. (the parking brake has to be set if you want to run the rear PTO though
    Mine will not start unless the gear selector is in Neutral as well.. So it shouldnt be an issue with a switch in the gear selector since the OP said it will start and run..
    Where is the seat sensor? is it wired inside the seat itself OR is there a pressure switch that is pushed down by someones weight? I have had my seat all apart but I dont remember seeing a separate pressure switch - but i wasnt looking for it to be honest..
    im still thinking seat switch is the issue..
    Brian
    Bedford, VA
Similar Threads
  1. John Deere LA 135 won't stay running
    By dpieterick in forum John Deere Lawn & Garden
    Last Post: 11-14-2017, 06:01 PM
  2. L3430 won't stay running
    By spock in forum Kubota Owning/Operating
    Last Post: 01-07-2013, 10:06 PM
  3. Mowing F935 won't stay running
    By DickD in forum John Deere Owning/Operating
    Last Post: 11-06-2011, 01:02 AM
  4. Oil & Fuel JD450B starts but won't stay running
    By Daveintexas in forum John Deere Owning/Operating
    Last Post: 06-13-2011, 05:31 PM
  5. 1527 diesel won't stay running
    By evan4434 in forum Cub Cadet Tractors
    Last Post: 04-28-2010, 08:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
