I recently purchased a new drive shaft for my 47 in blower. Old one was damaged. Removed the old one easily by removing the retaining pin and sliding the drive shaft off the shaft which exists from the bower.
I placed the new drive shaft onto the shaft coming out of the blower aligning the woodruff key as per the manual.
BUT when I attempt to re-insert the retaining pin it appears the holes done not line up. The holes on the shaft which exits the blower appear to be further in (closer to blower) than the holes on the drive shaft. The drive shaft is pushed as far onto the shaft from the blower as it can go.
This seems like it should be easy per the manual. But it is proving to be a pain. Has anyone else done this installation? What could I be missing?
The shaft from the blower does not appear to have any play. I tried to re-install the old drive shaft and am having the same issue.
Will try to call the dealer next week, but my guess is they will say 'bring it in". At a $100 per hour, I would prefer to try to fix this myself.
ANy help is appreciated.
Thanks
John
Thanks
John
