Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 26
  1. #11
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: Help with JD 855
    The dipstick on the transaxle that beenthere described is the dipstick to use to check the hydraulic oil level. The 855 uses a shared reservoir for the hydraulic implement pump and the transmission. Other than the engine oil dipstick, the only other oil level to check would be the front axle if it's a 4WD model. The recommended hydraulic oil is Lo-Viscosity Hy-Gaurd. Hold on to your shorts if you go to buy some... it's not cheap. I just priced a 5 gallon pail a couple weeks ago and it was about $100. The reservoir capacity is 4.5 gallons.
  2. #12
    Member
    Join Date
    Oct 2011
    Posts
    26
    just picked up a JD 855 today. The aforementioned dipstick was showing empty. so I guess i have to figure out where to by lo viscosity hy-guard and add it through the dip stick hole? also want to change oil and whatever else I can do myself, and I don't have a manual yet. any tips on something simple like an oil change? first time tractor owner.
  3. #13
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,903
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    JD will have all the fluids you need for it, if there is a dealer near you. There should be another port with a screw cap on it to fill the hydraulic fluid. I am pretty sure it doesn't go in through where the dipstick is at. Maybe someone else here can say for sure where it's located at, or your dealer can tell you.
    I've always used the Shell Rotella T 15-w40 engine oil in my tractors. Nothing wrong with the JD brand, of course, just my preference since the Shell is more readily available. Heck, even Walmart and Kmart carry it. Try to find some JD oil there lol!
    As for changing the engine oil, there is no magic to it. Just get yourself a new oil filter (this will probably have to come from JD) and enough oil. According to tractordata (see link below) the 3cyl Yanmar engine in the 855 requires 3.8 quarts of engine oil, so I would go ahead and buy a gallon container of new oil and one extra quart to keep it topped off with.
    Let the engine idle a few minutes to warm up the oil, then shut it off. Pull the plug and drain the old oil, and remove the old filter. Reinstall the drain plug after the old oil has drained out.
    Get the new filter and fill it about half way full of new oil. Take your finger and dip it in some oil and lube the rubber seal on the top of the filter.
    Spin the new filter on, but try not to spill any. If your filter is mounted horizontal, I would place a big rag underneath it to catch whatever does spill. This is when you HATE filters that are mounted horizontal!
    Refill engine with 3.7 quarts new oil (allowing for the little bit you already poured into the new oil filter). Crank it up and look for any leaks. If no leaks, you are done! Here are most of the 85 spec's:
    TractorData.com John Deere 855 tractor information
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  4. #14
    Member
    Join Date
    Oct 2011
    Posts
    26
    Thank you. gotta find the place to add the hydraulic fluid. all foreign to me because it is first tractor. guy gave me tons of extra filters, but just discovered they are all for a different tractor! bummer! I must have 10 different filters for oil, and gas, and they are all worthless to me. well gotta find a store near me to buy hydraulic fluid now. wish me luck.
  5. #15
    Veteran Member kiotiken's Avatar
    Join Date
    Aug 2011
    Posts
    2,497
    Dunrobin, Ont
    2012 Kioti DK45 HST Cab
    Quote Originally Posted by 2weelz4me View Post
    If it's the same as a 955, it's at the back, directly in the centre and under the seat area. I had a cab, so I can't say exactly what to look for, but that's the area you'll find it in.
  6. #16
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Circled in yellow
    Help with JD 855-855_hyd_fill-jpg
  7. #17
    New Member
    Join Date
    Jul 2011
    Posts
    24
    Jackson County, Southern Oregon
    John Deere 4x4 855 with 70a FEL
    There's two oil caps under the hood. What are they for?
  8. #18
    Silver Member v8only's Avatar
    Join Date
    May 2012
    Posts
    214
    Mb
    1988 John Deere 755
    to fill the oil.
    1988 John Deere 755
    52 Loader
    JD 59 Front mount snowblower
    60" MMM
    MFWD
    48" JD Model 40 tiller
    Craftsman YS4500
    22 Hp Briggs & Stratton
  9. #19
    Platinum Member JD755's Avatar
    Join Date
    Aug 2009
    Posts
    917
    Kansas
    John Deere 755 purchased new in 1993
    You can ignore the lower one on the side. It does the same thing as the one on the top.
    JD 755, 70 Loader, 60 inch MMM, Landpride rear blade, Modern box blade, Wallace subsoiler
  10. #20
    New Member
    Join Date
    Jul 2011
    Posts
    24
    Thanks for the useful comment. Now that I'm under there, does the fuel filter housing just unscrew? Am I not doing something there? It's a real PITA to get off!
Similar Threads
  1. JD 855 Slow Transmission
    By jimsing in forum Hydraulics
    Last Post: 04-14-2018, 07:40 PM
  2. Rotary Cutter What size rotary cutter for a JD 855
    By Boombollie in forum Attachments
    Last Post: 11-17-2011, 10:49 AM
  3. Can't keep fuel flowing on JD 855
    By kimodc in forum John Deere Owning/Operating
    Last Post: 09-11-2011, 11:01 PM
  4. Looking for a JD 855 Graveyard
    By 855Idiot in forum John Deere Owning/Operating
    Last Post: 06-01-2008, 09:05 PM
  5. JD 855 Front End Loader
    By Striker4972 in forum John Deere Owning/Operating
    Last Post: 05-15-2008, 12:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
