Gary Beaulieu
Member
I have a JD 2005 2210. It's been out in the cold for the past 3 days, 20 below. Anyway, I started plowing with it and noticed the pedals were coming up slowly when going forward and reverse. Then it got to the point that the forward pedal was up maybe 2" and wouldn't go down any further. I pressed the reverse pedal more which brought the forward pedal up and now the forward pedal is all the way up and will not go down. I can start the tractor in Neutral, but cannot put into gear because the reverse pedal is all the way down so the tranny is turning. Is it the dampening shock absorber doing this problem? or something else. I checked the trans oil, added maybe 1/2 quart to bring it back into the sight glass. Linkage seems alright underneath, you see it plays when I try to push the pedal, but it appears to be solid at the dampener shock. Could this have seized? Last year I had problems with linkage where the pedals returned to neutral slowly and this was dangerous because the tractor would not come to a stop quick enough. I oiled and lubricated the linkage and it was fine after that. Any suggestions is highly appreciated, my driveway is full of snow right now. Isn't this always the case? Thank you.
