Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    Member
    Join Date
    Jan 2012
    Posts
    39
    Beloit, Ohio
    John Deere 2030 / 1950 Case DC / 1973 John Deere 4230
    Default 1975 John Deere 2030 (401c)
    Hello to all out their. A 1975 John Deere 2030 (401c) it's having hydraulic problems. The reservoir is in the front of the tractor is empty. The reservoir is above the front pump and feeds it. Should the reservoir be empty at all. It looks like there is hardly any fluid flowing into it in idle. Also the line that comes out of the side of the pump pulsates. That line that pulsates, runs to the back for the rear hydraulics and for the power steering. The rear hydraulics chatter and creep up slowly. The power steering turns very hard, like it is starving for oil I should tell everyone that when i drive it down the road, the power steering is almost fine and the rear hydraulic go up almost normally. Could anyone tell me what my problem is ? I would greatly appreciate it.
    1950 Case DC
    1981 Chevrolet Caprice Classic 5.7 OLDSMOBILE DIESEL
    2012 Ram 2500 HD Cummins 6 Speed Manual Regular Cab
  2. #2
    Gold Member
    Join Date
    Jan 2012
    Posts
    373
    Northern Washington
    John Deere 3033R
    Default Re: 1975 John Deere 2030 (401c)
    Quote Originally Posted by JohnDeereFarm View Post
    Is there a fill line on the reservoir ? Add fluid to line might work.
    2016 3033R John Deere, X739 John Deere,X300 John Deere.
    Implements. Post Hole Digger Land Plane Landscape Rake Rear scraper Blade Box blade Pallet Forks Wood Chipper
    I drives me boat ! My wife drives me dingy !
  3. #3
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,938
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Sounds low on oil. And it sounds like you think that it is low on oil too. Add oil a quart at a time and see if there is any improvement.
  4. #4
    Member
    Join Date
    Jan 2012
    Posts
    39
    Beloit, Ohio
    The reservoir doesnt have a fill marking on it, but the transmission dipstick says it's full? The reservoir that I'm talking about is up front a foot above the hydraulic pump.
  5. #5
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    are you sure that isn't the fuel tank in the front i thought that tractor used the trans/rear axle for a sump for the hyd. oil
  6. #6
    Member
    Join Date
    Jan 2012
    Posts
    39
    Beloit, Ohio
    It does, but it gets pumped up to the Oiler cooler then from there it goes to a reservoir that is about 2 liters in volume. I herd these front pumps on the John Deere don't suck they get feed.
  7. #7
    Join Date
    Nov 2007
    Posts
    151
    NH
    JD 1520
    you have two pumps on that type tractor . there is a pump in the front of the trans that pumps oil to the main pump up front. if the trans pump isnt sending enough oil to the front pump you get low flow and pulsation. the power steering gets all the oil it needs before any thing else,so thats why the steering seems ok.that tank above the front pump is only there to supply oil to the main pump at times when the trans pump is disenguaged (clutch depressed)and to smooth out flow to the main pump. frist thing to do after checking the oil level is to pull the suction screen and clean it and replace the filter. refill the hyd oil and try it again. buy the way the trans holds around ten gal of hyd oil.if the screen or filter are dirty the trans pump cant supply enough oil to the front pump. and hyd dont work or work slow and jerky. did this happen all at once or over time?
    " If I`m curt with you its because time is a factor." "If my helps not appreciated lots of luck gentlemen."
  8. #8
    Member
    Join Date
    Jan 2012
    Posts
    39
    Beloit, Ohio
    I replaced the trans oil and filter with all John Deere Products. This tractor is really a 401c which is the industrial version of the 2030. It says in tractor data.com that the rear end holds around 8.5 gallons so do you think 10 gallon may be to much? I know it will hold it though. By the way the rear screen is clean. I'll put more fluid in it tomorrow morning. Also, I herd that the rear pump works only when the rear wheels are moving??
  9. #9
    Join Date
    Dec 2001
    Posts
    1,356
    Maryland
    Brimstone is right on. Check the sump screen and replace the filter first. If you have already done that, then we need to know how the tractor is equipped. Does it have a reverser? Hi-Lo shift? Independent PTO? The transmission pump supplies oil to those items and to transmission lubrication before any oil gets sent to the Main hydrauilc pump. These items can develop internal leaks that rob the oil from the main pump. Another item that can cause problems is the transmission oil filter relief valve. A piece of dirt can get stuck in the valve holding it open and dumping oil flow back to sump. The transmission pump does pump when sitting still. Depending on what type of clutch/pto you have, it can stop pumping when the clutch is pushed in.
  10. #10
    Join Date
    Nov 2007
    Posts
    151
    NH
    JD 1520
    if the dipstick shows full then it is all set . I just wanted to make sure you knew it was a lot of oil. how many hours on this rig . the pumps do wear out. also could have an internal leak in the trans or the rockshaft. the trans pump also supplys oil to lube the shafts/ gears, and some of them have a hyd pto system that could have a leak. or if the trans has a hi/lo unit. or if its a power reverser . when they work right their great when they dont it can become a major deal to fix. do you have the book sounds like know some about it?
Similar Threads
  1. New Holland or John Deere? Which one to buy?
    By Aranon in forum Buying/Pricing/Comparisons
    Last Post: 05-22-2011, 07:17 AM
  2. John Deere Noise Canceling Headphones
    By Fug1000 in forum Kubota Owning/Operating
    Last Post: 11-08-2010, 09:57 PM
  3. Dealer Another Deere dealership pulled
    By dgl24087 in forum John Deere Buying/Pricing
    Last Post: 01-29-2010, 07:36 AM
  4. JOhn Deere 2030 problem
    By bullrun in forum John Deere Owning/Operating
    Last Post: 09-13-2009, 11:09 AM
  5. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
