Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Gold Member
    Join Date
    Jun 2001
    Posts
    251
    SE Michigan
    John Deere 4300 HST
    Default 4300 rear end
    I am looking for some feedback on a potential issue. A few months back, I had a bearing fail on the left rear of my 4300, the bearing broke apart and was pushed thru the casing. A chunk of money and time later I got it back together and running. While I had the left rear off, I did everything I could to see if the right side was still solid. There was no play at all.
    I was out using it for the first time today; a little paranoid of course. Well everything seemed fine, except I hear an occasional ticking in the right rear if it's slipping and the left isnt moving. Just driving normal or with the diff locked, no noise. I don't remember if it did this before, since I never thought anything of it. It increases with speed, FYI. Anyway, now I am thinking about it!
    Can anyone verify if their similar model does the same? Lots of slipping here with snow and ice. I will tear the right side apart, happily rather than break it. I am, based on the symptoms thinking it's the differential making a "normal"'sound.
    Thanks for your help!
  2. #2
    New Member
    Join Date
    Oct 2011
    Posts
    11
    Default Re: 4300 rear end
    is this a Steiner/Jacobson 4300??? if it is then remove the parking brake off the rear transaxle. drive it and see if it goes away... talking from experience that can cause the transaxle to become noisy.
  3. #3
    Gold Member
    Join Date
    Jun 2001
    Posts
    251
    SE Michigan
    John Deere 4300 HST
    Default
    No, it's a deere. Sorry...
  4. #4
    Veteran Member rekees4300's Avatar
    Join Date
    Feb 2010
    Posts
    1,864
    Indiana
    JD4300 HST 4WD
    My 4300 has never made a ticking noise.
  5. #5
    Gold Member
    Join Date
    Jun 2001
    Posts
    251
    SE Michigan
    John Deere 4300 HST
    Default
    Maybe more of a click than a tick...seems to do it once per revolution of the tire.
  6. #6
    Join Date
    Jan 2007
    Posts
    1,882
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Are rear wheel bolts tight?
    Noise possibly could be the spider gears or shaft(parts key #8) in differential. Has tractor ever been run real low on trans/hyd oil??
    Attached Thumbnails Attached Thumbnails 4300 rear end-mp31346________un19feb03.gif
  7. #7
    Gold Member
    Join Date
    Jun 2001
    Posts
    251
    SE Michigan
    John Deere 4300 HST
    Default
    The rear bolts are tight. It's been run pretty low on fluid before when we had an unnoticed leak. It was Even pulled home about a half mile with no fluid after the left side rear blew out. It sounds like it comes from the right center or right side (somewhere between the diff and big bull gear)
  8. #8
    Join Date
    Jan 2007
    Posts
    1,882
    Coyote Flats,Tx
    IMHO pulling it 1/2 mile without hyd oil in it was looking for disaster. I would have hauled it instead of pulling it even I had to hire a roll-back truck. I'll bet you click is in the differential spider gears.
  9. #9
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Additional FYI. My JD 4300 doesn't have a clicking sound and have been out on ice several times clearing snow where one of rear tires loses traction.
  10. #10
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    Quote Originally Posted by Large Bear 13 View Post
    Thought this might be reference to a particular rear end in the deere 4300. Assume not, and that it DNA to the OP. Just wondering.
Similar Threads
  1. John Deere 318 Rear End Leak
    By rwc318 in forum John Deere Lawn & Garden
    Last Post: 05-12-2012, 01:26 PM
  2. Rear Axle Removel JD 4300
    By Boondoggle in forum John Deere Owning/Operating
    Last Post: 08-15-2011, 02:37 PM
  3. Gc2310TBL driveshaft rear end leak
    By Mac clarke in forum Parts/Repairs
    Last Post: 05-15-2011, 08:29 PM
  4. Ker-Chunk in L4330 rear end during/after tight turn
    By JonBarleycorn in forum Parts/Repairs
    Last Post: 11-06-2009, 07:11 PM
  5. Oil & Fuel Century Rear End Oil
    By EddieWalker in forum Zetor, Century & Branson
    Last Post: 06-02-2008, 10:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
