Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Feb 2012
    Posts
    3
    1990 John Deere 955
    Default 1990 John Deere 955, left brake stuck
    When I move forward it seems that the left brake is stuck, so much that if I continue engine will die under the load. Doesn't seem to stick in reverse. Any suggestions would be appreciated. At the moment I can't move the tractor.
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,431
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: 1990 John Deere 955, left brake stuck
    The brake lining has probably delaminated from the shoe and is piling up under the lining on the other shoe.
    Spring is the season of optimism.
  3. #3
    New Member
    Join Date
    Feb 2012
    Posts
    3
    1990 John Deere 955
    Thanks RickB, but it's a hydrostatic trans and has no brake shoes. I appreciate your reply nonetheless. Scott
  4. #4
    Join Date
    Sep 2000
    Posts
    9,431
    Just a Scag
    Quote Originally Posted by ticowannabe View Post
    OK, you have wet disc brakes. Check the operating shaft and see if it is seized to the cover where it enters the brake housing. It should have several degrees of relatively free travel matching the pedal freeplay spec in your operator's manual.
Similar Threads
  1. John Deere 2155 Stuck in Reverse Gear
    By rccarpen in forum Parts/Repairs
    Last Post: 08-24-2011, 05:33 PM
  2. Nice lunch with John Deere reps.
    By cowboydoc in forum John Deere Buying/Pricing
    Last Post: 09-02-2003, 10:48 PM
  3. John Deere 4400 problems
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-15-2002, 10:07 PM
  4. JD 4000 series wheel bolts
    Last Post: 04-13-2002, 11:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
