Results 1 to 3 of 3
  1. #1
    Veteran Member Red Horse's Avatar
    Join Date
    Dec 2010
    Posts
    1,004
    Bolton, MA
    Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
    Default 4720 Cab -Electrical Gremlin
    Guys- any opinions? today after doing a couple of grapple loads of firewood, its getting dark and I'm about to drop the grapple to put the plow on as we are supposed to get up to 8" tonite. I put the lights on and the minute I get past the hazard position, machine shuts down and is dead. Turn key, dash indicators come on but that is it.
    After a few minutes I get dash indicators, code 61-which is right tail lamp, it starts but again, minute I turn light switch past Hazard it shuts down.. I pull the fuse block cover push all the fuses then grab a wire connector that has about 3 wires on it- I'm bending it while holding key and it starts and lights work. end of issue =on/off, lights on/off, no issue.
    Anyone have any thoughts? the right tail light by the way works.
    Appreciate any insights
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,767
    Upper Midwest USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: 4720 Cab -Electrical Gremlin
    No ideas beyond what you discovered...that the issue is in the wire connector. Look at it closer in the daylight to see if there is a wire loose or a bare wire touching ground.
    Good luck with it, and hope it never happens again...
  3. #3
    Join Date
    Dec 2010
    Posts
    1,004
    Bolton, MA
    Quote Originally Posted by beenthere View Post
    10-4, thx. no logic to it.
Similar Threads
  1. Anybody know the 1972 Hinomoto Combac?
    By jsw44 in forum General Vintage Tractors
    Last Post: 09-27-2015, 07:25 AM
  2. 4720 Cab, Stuck Parking Brake.
    By Red Horse in forum John Deere Owning/Operating
    Last Post: 03-08-2012, 09:27 PM
  3. Price Check 2007 John Deere 4720 Cab
    By Sawdust Farmer in forum John Deere Buying/Pricing
    Last Post: 03-03-2010, 09:36 PM
  4. New 4000 series cab tractor - 4520 or 4720?
    By AKfish in forum John Deere Buying/Pricing
    Last Post: 01-01-2010, 11:59 AM
  5. 4720 Cab Tractor Slow to Warm UP
    By TCowner in forum John Deere Owning/Operating
    Last Post: 12-17-2008, 10:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
