cdaledave89
I have a 2009 4520 w/ about 110 hours and noticed a problem last night with, what I think, is the power steering system. After parking in the barn and while still idling, I could feel "hammering" or "bumping" in the steering wheel. I left it running and got out to check around the tractor. I traced the hyd lines from the PS cylinder to the right side of the tractor and I put my hand on the hard piped hyd line that is vertical and is closest to the cab. I could feel the "hammering" or "pulsing" in the line. Totally random. It feels like when you close a hyd valve and the pipe or hose shudders. Except I'm not turning the wheel or putting any load on the PS system at all.
I did a search on here last night and read about the instances where the fittings were loose at the cylinder and air was getting into the system. "That must be it!", I said and ran to the barn to check the fittings. I checked the tightness of all of the PS hyd line fittings that I could reach (with the exception of the ones that go into a block right in front of the cab and below the steering wheel). They were all tight. So I started the tractor again and checked it. It didn't do it at first, but after idling for a few minutes, it started "hammering" again.
Any idea what it could be?
