Results 31 to 40 of 72
04-04-2012, 06:54 PM #31Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
Re: Unvenferth Spacers on a JD3730?
This new breed of JD compacts have cast aluminum rears. That's the problem. Spacers add no down pressure by themselves, They're merely an extension of the hub. Loader - front implements in general - actually lighten the load on the rear axles. Spacers in general work just fine.
Ground engaging equipment however, typically has the opposite effect; backhoes in particular. Widening the rear track in those cases - among other things - will almost certainly increase stress on the JD cast aluminum axle housings. Yes, the outriggers are supposed to take the brunt of that force. But guess what will go next if one of those outriggers either slips or fails altogether.
//greg//USN (Ret)
Former Chinese tractor owner (x4)
Current John Deere owner
04-05-2012, 06:46 AM #32
Mr Greg,
Now you have me confused. You are saying in your last post that spacers with a backhoe could be hard on the housing but in this quote you are saying that the JD manual says it is acceptable to go out another 4". What difference does it make to the housing whether the rims get it out to the 68" or it is done with spacers. I'm not trying to be difficult, just understand.
BobJD 3320, 300CXFEL, Woods BH80-X Hoe with HYD thumb conversion, WR Long OBG2 48" grapple,
Salsco 627 3PT Chipper, Timberwolf 3PT splitter,
Fisher 7-1/2 FEL Plow, HTL, Front forks, landPride 6' rake
Some of my Projects are here: http://www.acdseeonline.com/user/THE_REMDOG/
04-05-2012, 07:58 AM #33Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
None. That was my point. That is the argument I made to the JD dealer when they refused to sell/install spacers on my 3720. But I see your point too. Only thing I can come up with is that TLBs are typically on R4 tires. And due to the OE rim offset, a pair cannot be physically set wider than 59.7 inches. That's the width at which they'd support backhoe operation. Whereas 4" spacers on R4s still puts the physical width within the JD R1 spec of 68.4", they've not added any down pressure. No threat to the aluminum rear end. But add a backhoe and start busting hardpan, and you've created the potential for imposing significant downforce on what amounts to extended axles. The axles then transfer that force to the bearings, which in turn transfer it to the aluminum axle housings. They're the weak link that concerns John deere.
//greg//USN (Ret)
04-05-2012, 09:46 AM #34
Thanks Greg for the info. I do a ton of backhoe work and as much as I would love to have a wider stance out in the woods, I cannot take a chance on doing any damage.
04-09-2012, 10:14 AM #35
04-27-2012, 01:13 PM #36Gold Member
- Join Date
- Nov 2011
- Posts
- 309
- Location
- Enid, OK
- Tractor
- 2012 John Deere 3720 eHydro
Can't wait for mine to arrive!
05-05-2012, 03:32 PM #37New Member
- Join Date
- Mar 2012
- Posts
- 11
- Location
- Bolivar, Texas
- Tractor
- 3203 John Deere
Well, I've had my JD 3203 on 3 wheels quite a few times, and finally bit the bullet.
I picked up a set of 6" spacers from Kubota John deere Compact Tractor Utility Vehicle Wheel Spacers
It took around 5 weeks or so to get them, but I was told this up front.
Christian was very easy to deal with. He also provided updates throughout the process.
They came in the mail today, and didn't take long to install. The welds are great. Paint is very nice as well. Great product!
The insides of the wheel are now lined up with each other with both front and back wheels set to the wide position. Going to try it like this for a while, but may flip the rears to the narrow position. Have to see how it does on the trails.
Took a ride across one of my hills and there is a huge difference in stability.
Makes the center of gravity feel much lower.
I would highly recommend to anyone with hills.
05-05-2012, 05:53 PM #38
Here is a set I purchased for my JD 3203 . Kubota John deere Compact Tractor Utility Vehicle Wheel Spacers
6" with bolts shipped $427.00.
Shipped from Cal. to WV.
Great spacers.Lord Help me to be the person my DOG think's I am !!
Problem is those that work are outnumbered by those that VOTE !!!!
3203 JD ,300 FEL, 5 ft. King Cutter Brush Hog, 6 ft. Box Blade, Hay Spear, JD Scraper Blade, 1986 Ford Ranger Farm Truck.
40 Caliber Glock with me at all time's.
05-05-2012, 09:51 PM #39Platinum Member
- Join Date
- Dec 2005
- Posts
- 622
- Location
- Central Maine
I'm not sure that's quite true Greg, if the R4 width was the limiting factor with the backhoe I would think that Deere would refuse to sell the backhoe with R1's but they don't....
I don't think Deere really thought about it and the dealer is definitely not going to go out on a limb. If Deere doesn't sell it, they won't condone it or service it whether or not it works from an engineering point of view.
No company ever supports user modifications to the tractor and it's much easier to maintain a rigid line from the company and dealer point of view. That way they don't have to analyze 18,000 different user situations when something breaks.
It's too bad really, the 3x20 series are fantastic tractors and the spacers move them from fantastic to perfect....personally, I put spacers on mine and would do it again....
05-05-2012, 10:54 PM #40Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
Charley
I think you explained that pretty well.
Similar Threads
2305 Wheel Spacers
By hink10 in forum John Deere Owning/OperatingReplies: 13Last Post: 05-16-2011, 08:55 PM -
Wheel Spacers for Trailer?? Opinions?
By CHDinCT in forum Trailers & TransportationReplies: 20Last Post: 08-22-2010, 10:57 AM -
Cheaper wheel spacers for 40x20 series and 110.
By AKfish in forum John Deere Owning/OperatingReplies: 15Last Post: 08-17-2010, 07:35 PM -
BX24 WHEEL SPACERS DIFFERENT SUPPLIER
By dhagerty in forum Kubota Owning/OperatingReplies: 15Last Post: 09-30-2009, 03:03 AM -
Wheel spacers for Mahindra 2615, 2815, 3015
By Wyld Bill in forum Mahindra Owning/OperatingReplies: 41Last Post: 05-27-2009, 05:14 PM
