Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Gold Member
    Join Date
    Sep 2010
    Posts
    294
    Midcoast Maine
    Yanmar YM186D
    Default Re: need help with hook ups on john deere 750 to hook up FEL
    This should help, it's from my yanmar 186d manual, but they are cousins, yanmar made those deere. You are close, you just need a little plug inside the diverter block to force the flow the the loader valve. Without it the flow can just short right to the 3ph, which is why you could get some action when messing with the hitch.
    Attached Thumbnails Attached Thumbnails need help with hook ups on john deere 750 to hook up FEL-dscf2026-jpg
  2. #12
    Member
    Join Date
    Jun 2009
    Posts
    34
    Default
    Quote Originally Posted by JCByrd24
    And just remember if you ever removed your loader you will need to remove the plug. If not the Hyd system will run in relief and the rockshaft will not function.
  3. #13
    Gold Member
    Join Date
    Sep 2010
    Posts
    294
    Midcoast Maine
    Yanmar YM186D
    It'd likely be worse than running in relief and non-fuction. Per the note in the lower right of that page, pump breakage is likely to occur. The relief is in the 3ph valving downstream of the diverter block so without removing the small internal plug when re-installing the external plugs the pump would be deadheaded and would shear the key or damage the pump.
    To clarify, this is if you remove the loader permanently like if you sold it. Just removing for non-load work is not usually a problem.
    When the valve stays with the tractor and the QDCs are in the working ports there is almost zero risk of the above.
    Some loaders are plumbed so the loader valve removes with the loader, so the QDCs are in the pressure and return line vice working ports and you have to connect them together when the loader is removed, or else what is described above happens. This is a very bad way of doing the plumbing on this tractor.
  4. #14
    Member
    Join Date
    Jun 2009
    Posts
    34
    Quote Originally Posted by JCByrd24 View Post
    Thanks for the clearing it up.
    I was thinking that the relief was before the diverter block at the RCV to also protect the add on loader. If not the pump woud be damaged if the loader cylinders where fully extended,retracted or if the bucket was overloaded.
  5. #15
    Member JohnDeereHere's Avatar
    Join Date
    Jun 2009
    Posts
    43
    W-S,NC
    1997 John Deere 670 4wd + 1987 John Deere 655 2wd+1984 John Deere 650 4wd
    Here are some pictures,as well as the John Deere tech manual illustration.Maybe this gets us closer.
    Attached Thumbnails Attached Thumbnails need help with hook ups on john deere 750 to hook up FEL-john-deere-650-dscv-001-a   need help with hook ups on john deere 750 to hook up FEL-apple-iphone-032312-059-jpg   need help with hook ups on john deere 750 to hook up FEL-apple-iphone-032312-060-jpg   need help with hook ups on john deere 750 to hook up FEL-apple-iphone-032312-062-jpg   need help with hook ups on john deere 750 to hook up FEL-apple-iphone-032312-061-jpg
    1997 John Deere 670 4wd,60 loader
    1987 John Deere 655 2wd,50" belly mower
    1984 John Deere 650 4wd,60" belly mower
    1983 John Deere 210 46" deck
    1981 John Deere 210 39" deck
  6. #16
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,745
    South West MI
    John Deere 2030, John Deere 6415
    From what John DeereHere posted, your loader valve must have three ports for hydraulic lines. IN, OUT and POWER BEYOUND.
    IN the next picture it shows two HEX PLUGS to the right of the vertical steel line. Top hex plug is labeled "I" Bottom hex plug is labeled "O"
    From the hex plug labeled "O" go to IN port on the loader valve.
    From the hex plug labeled "I" go to the POWER BEYOND port on the loader valve.
    From the OUT port of the loader valve you need to find a place to return the hydraulic oil to the transmission case (sump). There must be a plug for that on the side or top of the transmission case some where.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  7. #17
    New Member
    Join Date
    Apr 2013
    Posts
    1
    Winnipeg, Manitoba
    John Deere 750
    Hi guys ! New on here and just picked up a JD 750 with an Allied Loader on it. Whoever installed the loader replaced the stock JD Hydraulis controal valves with a slick joystick and the loader works great. However my 3 point hitch doesn't work at all.
    The Power Beyond port on the joy stick is not connected to the Return (or I) port on the tracter and I'm thinking that's why the 3 Poiint hitch isn't working. With the internal plug installed into the O port I'm assuming that the I port now becomes the source port for the 3 point hitch. Am I getting this right?
    Surley there must be a way to get both implements working at the same time????
    I'm going to map out the hoses tonight but any help you could give me would be greatly appreciated.
    Thanks
    Exciterfan
  8. #18
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    to TBN from New-Brunswick
    Henri
    How could you be told I was french?
    Rotary cutter 4' Howse , mid mount mower 54'' , f.e. loader 200CX , tiller RT1150 Frontier , cultivator PC1001 Frontier , middle buster PM1001 Frontier , JD 47'' front snowblower , pallet forks , 4' boxblade Agriease , grass-sweeper , quick hitch Speeco , trailer hitch , cab Jodale-Perry , trailer 16' galvanized Easy-Hauler ,
Similar Threads
  1. John Deere 750 Compact Loader
    By jgbanshee in forum Private Party Ads
    Last Post: 05-05-2012, 04:58 PM
  2. Loader John Deere 4200 CUT W/ 300CX FEL
    By kdm004 in forum John Deere Owning/Operating
    Last Post: 11-25-2011, 03:05 PM
  3. John Deere 750 unequal turning radius
    By syxxty in forum John Deere Owning/Operating
    Last Post: 07-19-2010, 11:49 AM
  4. Kubota B3030HSDCC cab or John Deere 3720 cab? Please help!
    By FRIZ in forum Buying/Pricing/Comparisons
    Last Post: 07-16-2009, 05:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
