Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jan 2012
    Posts
    16
    Frederick, Md.
    Default 60 MMM auto connect question
    While looking at the 1026R...I saw a garden hose port on the mowing deck.
    The salesman says this is for cleaning under the deck.
    Anyone use this?
    How effective is it?
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,921
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Default Re: 60 MMM auto connect question
    Three things come to mind.
    One is a safety concern, as the water has to be turned on and then the mower deck operated. Can be done, but cumbersome.
    Two, there needs to be a place for the wet grass juice and water to run off. Don't want it in the lawn or the drive or running down the gutter.
    Three would be my interest in keeping the deck as dry as possible, not wet. And I don't find a buildup of much debris like grass etc. under my decks. Mowing when grass is not wet and having some sticks and hickory nut husks prolly helps that.
    That said, some may like using the water connection to clean their decks. Just not I.
  3. #3
    Elite Member bigtiller's Avatar
    Join Date
    Feb 2006
    Posts
    3,548
    central Iowa
    JD 2720
    I've never used one but it seams to be a great way to make a mess. If I had this mower, I think I would rather take the deck off and lift it up with a boom pole or the FEL and clean it. But I would have to try the wash port once just to see how well it works.
    HAVE FUN
    Life is easier when you plow around the stumps.
    2720
  4. #4
    Bronze Member bradrich18's Avatar
    Join Date
    Aug 2011
    Posts
    83
    Central Alabama
    John Deere 1026R
    Default
    I have the 60d with the hose attachment on my 1026r. I use it and it seems to work. When I remove my deck for cleaning, I'll usually raise the deck and check/clean underneath it. When I do this, theres rarely anything caked up underneath. When I use the attachment, I run the deck at the suggested cutting rpm for at least two minutes.
  5. #5
    New Member
    Join Date
    Jan 2012
    Posts
    16
    Frederick, Md.
    Thanks for the replies. Really like the 1026R.
  6. #6
    Elite Member KennyG's Avatar
    Join Date
    Jan 2011
    Posts
    2,601
    SW Michigan
    John Deere 2320
    I've never used the port on mine. I try not to mow wet grass and I clean it once a year in the fall by mowing leaves. Run through the leaves and acorns for an hour or so and it's pretty clean.
Similar Threads
  1. Mowing 54 or 60 inch mmm
    By Chugbug in forum Kubota Owning/Operating
    Last Post: 03-28-2010, 06:31 PM
  2. John Deere Auto Connect 72" MMM
    By jsboening in forum John Deere Owning/Operating
    Last Post: 11-29-2009, 02:41 PM
  3. Auto Insurance Question
    By Greenmountain Farmer in forum Related Topics
    Last Post: 03-10-2009, 04:23 PM
  4. b2320 enough power for a 60 in. mmm?
    By steverichmond in forum Kubota Buying/Pricing
    Last Post: 09-25-2008, 03:01 PM
  5. HST + auto hds question.
    By lawn_king in forum Kubota Owning/Operating
    Last Post: 08-24-2008, 04:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
