Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    3
    Presque Isle, ME
    John Deere 3720
    Default 3720 - Front Hub Leak
    I've got a 3720 that has a left front wheel hub seal that just started to leak. Not bad but enough. It is not the knuckle seak so I assume this should be pretty easy to do.
    I've got the know how and the tools but lack the manual to judge what I'm getting into before tearing it apart. Not to mention the torque specs for assembly.
    Where do I locate one?... Can it be ordered online?
    Thanks.
  2. #2
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Default Re: 3720 - Front Hub Leak
    Check out other threads on the leak. For some, including myself, the leak came from the oil heating and not having a place to vent.
    I cracked the fill plug to allow for expansion, and end of leaking.
    Also some threads on R&R of the wheel hub.
    Yes, the tech manual can be ordered online through deere.
    Order Manuals and Parts Catalogs from JohnDeere
  3. #3
    New Member
    Join Date
    Mar 2012
    Posts
    3
    Presque Isle, ME
    John Deere 3720
    Thanks BeenThere..... I've suspected that it wasn't venting correctly. When I turned out the fill plug I heard a lot of air escaping or entering... It now leaks just sitting there, so I suspect it is new seal time. I'll check out the manual.
    I didn't seen information about manuals in the other thread.. .only really saw one... so had to ask.
    Thanks!
  4. #4
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    eBay has the manual for $169.99 I noticed. Paper.
    Sometimes a used one comes up, and I like mine on a CD.
    On CD through deere the TM2138 manual (no cab) is on CD for $115.
    Need to be sure the manual is for the tractor and s/n that you have.
  5. #5
    Padawan Tractor Learner
    Advertiser
    Johndeere3720's Avatar
    Join Date
    Mar 2009
    Posts
    6,341
    NW Oregon
    Deere 317 & L118
    I have some experience in replacing a seal in the front axle of a Yanmar tractor I used to have. When my seal blew I believe it was due to low oil levels in the front axle. When the front axle is low on oil it heats up the seals due to friction and eventually warps them. Then you start to notice oil leaking. When the oil heats up it expands which compresses the air to an extent within the axle which also helps drain oil when seals blow out.
    I would check the oil level in your front axle. If it is good then it has a venting problem which forced the oil past the seal. If it is low on oil I would assume it heated up hot enough to warp a seal which and now it leaks oil. Just my
    My Fleet:
    2004 Deere 317 Skid Steer Loader
    66" Construction bucket, imatch QA adapter, CU72 Jake Rake, Middle Buster, 60" Landscape rake, 54"x 48" Pallet forks
    2005 John Deere L118
    42" deck
    Check out my rakes: www.Jakesimplements.com
    Check out the latest small engine I am working on: http://www.northwestsmallenginerepair.weebly.com
    Member of the TBN "Young gun" Club
Similar Threads
  1. Need help for oil leak front case bevel gear Kubota
    By Mario2 in forum Parts/Repairs
    Last Post: 06-28-2010, 01:35 PM
  2. Needs some help. Leak in front hub.
    By lzicc in forum Kubota Owning/Operating
    Last Post: 07-25-2009, 10:45 PM
  3. tires
    By Waterrat in forum Parts/Repairs
    Last Post: 03-13-2009, 06:23 PM
  4. Stuck front hub on a TU155
    By Chris_in_Oz in forum Iseki
    Last Post: 03-03-2009, 07:38 AM
  5. Oil & Fuel 1610D Gear Oil Leak Front Hub Area
    By rvee40 in forum Yanmar
    Last Post: 08-26-2008, 01:15 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
