Results 1 to 10 of 38
04-09-2012, 10:00 AM #1
Fuel Filter
I am having one heck of a time removing the fuel filter on my JD 2520. Has anyone had similar issue and any suggestions on what I should do? Obviously I don't want to screw something else up in the process.
JD 2520, 200CX Loader, 62D MMM
There are two ways to get to the top of an Oak:
1. Climb
2. Sit on an acorn
04-09-2012, 11:15 AM #2Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
Re: Fuel Filter
Trying to interpret what the problem is.
What are you trying that isn't working? Access? Tight screws? ??
04-09-2012, 11:58 AM #3
04-09-2012, 01:04 PM #4Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
Re: Fuel Filter
(edit: as Roy points out in following post, yours is likely the compact 2520, so follow his advice. Just have something to counter hold when getting a wrench on the large knurled plastic nut)
Are you removing the bolt that runs up through the filter?
Don't think it is a spin-on filter, but may be mistaken.Last edited by beenthere; 04-09-2012 at 01:28 PM.
04-09-2012, 01:20 PM #5Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,683
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Re: Fuel Filter
The OP's machine is a compact, not the old row crop tractor.
IF it's the compact, this is the procedure:
Cleaning Sediment Bowl and Replacing Fuel Filter
MX22568
1. Move the fuel shut-off valve (A) to the closed position.
2. Position drain pan under fuel filter sediment bowl (B).
3. Turn locking collar (C) counterclockwise to remove bowl.
4. Remove and discard the fuel filter.
5. Clean bowl.
6. Install new filter to filter head.
7. Install sediment bowl and locking collar.
8. Open fuel shut-off valve.
NOTE: Fuel system is self bleeding.
9. Crank engine to bleed fuel system.
Is it the locking collar giving you problems?
If so, are you trying to turn it by hand, or are you using a wrench? If you're using just your hand, I suggest you try a strap wrench (on the locking collar) for better leverage.Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
04-09-2012, 05:34 PM #6
Re: Fuel Filter
Piedmont,are you talking about the spin on filter, or the sediment filter?
I had the same problem with my spin on when I did my 50 hour. I just used a very large set of channel lock pliers. That,or a strap wrench may work.
Greg2009 2520
FEL/61" HD bucket/replaceable cutting edge
62D2 MMM
IMatch Quick Hitch
Homemade 3PT Receiver
Homemade Ballast Box
Woods GB65 Box Blade
A "REAL" snow blade --- JD 380A
90% Restored 1987 JD 316
MY BALLAST BOX:
http://www.tractorbynet.com/forums/b...box-build.html
MY SE SEAT 2520 MOD:
http://www.tractorbynet.com/forums/j...my-2520-a.html
04-09-2012, 05:59 PM #7
04-09-2012, 06:16 PM #8
Re: Fuel Filter
Had the same issue on my 2305, used a strap wrench and came off without damage. Follow RoyJackson's advice.
2008 JD 2305, Hydrostatic, 200CX FEL,
Frontier LR2048L Rake, Frontier BB2048 Box Blade,
Tooth Bar, Harbor Freight Quick Hitch
Bro-Tek front and mid mount Skid Plates
JD Noise Canceling Headset
Mad Dog ATV Chainsaw Holder
__________________
2008 JD LA175, Hydrostatic, 54" Deck,
Power Blower and Bagger, 17 cu ft Brinly-Hardy Poly Cart,
JD 2.3 Cu.Ft Spreader, JD Lawn Tractor Cover
04-09-2012, 08:02 PM #9
Re: Fuel Filter
2009 2520
62D2 MMM
IMatch Quick Hitch
MY BALLAST BOX:
04-09-2012, 08:04 PM #10
Re: Fuel Filter
2009 2520
62D2 MMM
IMatch Quick Hitch
MY BALLAST BOX:
Similar Threads
Massey 255 Fuel Filter Change
By ark_team_roper in forum Oil, Fuel & LubricantsReplies: 3Last Post: 07-26-2012, 10:48 PM -
Oil & Fuel JD 5420 Fuel Filter - Wish List
By burnetma in forum John Deere Owning/OperatingReplies: 10Last Post: 04-23-2011, 04:50 PM -
Maybe we should have gotten a crankcase heater in the L3940!
By Grateful11 in forum Kubota Owning/OperatingReplies: 100Last Post: 12-21-2010, 08:23 PM -
Bad fuel aftermath
By farmgirlky in forum Kubota Owning/OperatingReplies: 31Last Post: 08-23-2010, 08:40 PM -
Oil & Fuel Fuel Filter Change - Fuel Spill
By bcarter in forum Kubota Owning/OperatingReplies: 5Last Post: 12-08-2004, 10:19 AM
