Results 1 to 10 of 15
04-12-2012, 06:15 AM #1Silver Member
- Join Date
- Jun 2008
- Posts
- 221
- Location
- Kentucky
- Tractor
- John Deere 3320 - gator cx
3320 which R4's..
I'm thinking of upgrading the R4's on my 3320. I currently have the 19.5(smaller) R4s. Thinking of going to the larger ones. Is there any advantage to the different tread design of the larger R4s over the smaller ones? I know the 43x16-20's are 2 1/2 inches taller than the 19.5's. That would give me some added clearence with the belly mower on. What are your guys opinions?
04-12-2012, 06:32 AM #2Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
Re: 3320 which R4's..
I went with the taller ones for two reasons; ground clearance and cost. Higher price is almost certainly due to the heavy duty nature of their construction. It's my guess that the shorter ones are intended for those who intend to do a lot of backhoe work. Given that I don't own a backhoe attachment, I just couldn't justify the extra cost.
//greg//USN (Ret)
Former Chinese tractor owner (x4)
Current John Deere owner
04-12-2012, 07:17 AM #3
The big ones look cooler
3720, Frontier 6' BB; 6' Rear Blade.; Loaded tires and Ballast Box; Dirt Scoop.
X740; 62" Deck; w/47" Snoblower; 42" Hydraulic Tiller.
54" Front blade; 48" Belly Blade
04-12-2012, 08:48 AM #4Silver Member
- Join Date
- Jun 2008
- Posts
- 221
- Location
- Kentucky
- Tractor
I agree, the big ones look cooler also. I was wondering about the backhoe stuff. My 447 probally wouldn't have long enough stablizers to reach the ground. I could always fix that. I just found that Galaxy also makes that tread patteren in the 19.5 size. Might have check them out.
04-12-2012, 12:17 PM #5Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
Are the larger ones 6 ply?
That is what I like about my R4's, as I am in the woods a lot. Also like the lower center of gravity which is an issue for me.
edit:
From what I can tell, the larger are 4 ply.
I'd be interested in where I can see a pic of the larger ones.Last edited by beenthere; 04-12-2012 at 10:35 PM.
04-12-2012, 07:13 PM #6
I've thought about the larger r4's for my 3320 also. But since the smaller ones have a higher load capacity it's kind of foolish to get rid of them for ones that just look cool.
MattLast edited by GreatWhitehunter; 04-13-2012 at 01:21 PM.
3320 TLB , Woods box blade , , JD snow plow, 2500hd Dmax crew , PJ dump trailer , Belmont 12k tilt bed trailer, Millonzi grapple, Woods Harley rake, Horst Forks, 5' Woods Brush Bull X, Woods PHD35 9" auger, Frontier 60" 4in1 bucket, custom 60" rock bucket, BearCat chipper/shredder
04-12-2012, 08:20 PM #7Bronze Member
- Join Date
- May 2011
- Posts
- 73
- Tractor
- John Deere 3320
I have the 'bigs' and when compared to the 'smalls', here's some of my feelings.
If you load the tires you get about 100lbs more each.
The bigs use different wheels. The combination of different wheels with different offset, plus the extra width of the bigs will change your interference distance with the 3pt. sway links. (my reading is only 3/4" between the rim and the link,that's why I'm buying spacers).
The bigger diameter will mean a change to the tire size in the tractor's computer controller. The default size(circumference) in the computer is 2972 mm). The bigs size is 3287 mm. (essentially if you don't change it the tractor acts like its acceleration is in 10% overdrive(weak off the line)...I complained to my dealer after a couple of days use and the tech came out with his JD computer and made the change).
If you want the looks, not the functionality, and feel like laying out more coin for the new wheels...then the bigs are what you will probably get. But from a functional view I feel the smalls get the job done.Dave
JD 3320 E-Hydro, 300CX, Landpride RB3584 rear blade, Landpride SF2566 scarifier, W.R. Long toothbar, Timberwolf TW-P1 log splitter and big R4s loaded with Rimgard, Artillian 42" pallet forks.
04-13-2012, 07:02 AM #8Super Member
- Join Date
- Dec 2003
- Posts
- 5,587
- Location
- Western Kentucky
- Tractor
I forgot to list one other benefit of the taller R4s, relative to ground clearance. Right now I sit high enough to carry 5 foot round bales with a conventional TPH bale spear. But even at max lift height, the bale doesn't come very far off the ground. I've run through ruts deep enough to bottom out the bale and pull it right off the spear. That tells me I have no business trying to move 6 footers. One solution would have been to get the type of bale carrier that lifts from the bottom rather than from the center, but that horse is already outa the barn.
//greg//USN (Ret)
04-13-2012, 09:07 AM #9Silver Member
- Join Date
- Jun 2008
- Posts
- 221
- Location
- Kentucky
- Tractor
That was also a concern of mine to B58. Was mainly curious if the tread design is any better. Now since I found them in my 19.5 size.
04-13-2012, 09:02 PM #10Bronze Member
- Join Date
- May 2011
- Posts
- 73
- Tractor
- John Deere 3320
OK, I see the second part of your question. I went to Galaxy's website and found the page on the Marathoner R-4 which is the model of the big R-4. I see the 19.5 listed with a 4ply rating. That being the case, I would say they would be a better riding and better grip than the standard 6 ply 19.5(as long as you keep the pressure around 15psi). Galaxy says they eject mud better and offer "great pulling power".
However, I agree with the other guys when they say if you're running a hoe the 6 ply would be better. Were you planning on loading them with anything?Dave
Similar Threads
JD 3320 & attachments - extensive review
By loingrader in forum John Deere Owning/OperatingReplies: 28Last Post: 08-25-2011, 09:51 PM -
Are R4's Really Bad In The Snow?
By coollx in forum John Deere Buying/PricingReplies: 29Last Post: 04-26-2011, 11:37 PM -
3203 vs 3320
By JimParker in forum John Deere Buying/PricingReplies: 14Last Post: 10-05-2006, 04:53 PM -
3120, 3320, 3520, 3720 - how to decide?
By Doug_Norman in forum John Deere Buying/PricingReplies: 26Last Post: 08-24-2005, 12:47 PM -
3320 or 4115?
By ted5487 in forum John Deere Buying/PricingReplies: 4Last Post: 05-21-2005, 08:45 AM
