Results 1 to 10 of 20
04-13-2012, 08:21 PM #1Platinum Member
- Join Date
- Jan 2012
- Posts
- 933
- Tractor
- 2012 John Deere 3520 Deluxe Cab
Adding hydraulic top link to 3x20 or 4x20. need help
i titled it 3x20 and 4x20 for future searches for others. I have searched to no avail. Im totally new to these bigger john deere tractors and need to know what to order along with a hydraulic top link. I have a 3520 delux cab so the machine has rear remotes that work off the toggle switch on the loader joystick. I beleive the hydraulic top links only just come with the piston itself so I need to what to order such as:
-What size hydraulic hose and what length you guys are using
-What fittings i would need to screw into the hydraulic ram
-(dont know where to start with this one ) what quick disconnects do i need to fit into the john deere remotes that came with the tractor? Part number or aftermarket website link would be nice
Hey and thank you very much for your time
04-13-2012, 11:12 PM #2
Look up mtnviewranch here on TBN he sells the cylinder, hoses, and couplers. I'm thinking its fitritehydraulics.com if not just look him up and he has a link in all his posts.
Bobcat CT235 with Deere Imatch, And a very bad addiction of attachments
04-13-2012, 11:37 PM #3Veteran Member
- Join Date
- Aug 2010
- Posts
- 2,042
- Location
- South West MI
- Tractor
- John Deere 2030, John Deere 6415
Re: Adding hydraulic top link to 3x20 or 4x20. need help
Most guys are using 1/4" hydraulic hose. the smaller size will slow the cylinder making it easier to control. 36" seems the most common length.
Depends on what cylinder you buy. You MUST match to it's threads. I prefer SAE ORB. both mean the same thing. Both seal with an O-Ring
I like John deere part number AR94522 Male hydraulic tip. These have SAE #8 ORB threads. Then I adapt them to what ever fitting my hose has. I like hoses with Female 37 degree swivel fittings known as JIC. You can buy ORB to Male JIC adapters. Some will tell you to use NPT National Pipe Thread since it's a cheaper way to go than JIC/ORB and you will not be taking them apart once put together. Choice is yours.
Another thing to consider is cylinder check valves. They hold the cylinder where ever it has been set. I don't see a need, most likely you will be adjusting the cylinder more than it will be moving on it's own. Again your choice.
Finally you might find a choice on the port location on the cylinder. Top or side. With top you can have your fittings at either 12 or 6 o'clock. Side 3 or 9 o'clock.John Deere 2030 JD 245SL Loader
John Deere 6415 mfwd JD 640SL Loader
04-14-2012, 12:52 AM #4Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
Or underneath like I put mine.
04-14-2012, 01:58 AM #5Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,888
- Location
- 4000\' mountains of Southern California
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
$260 for a complete Top Link kit + shipping. That gets you a 2 1/2" dia cylinder with a 1 1/2" dia rod with a 10" stroke with a working length of 20"-30".
2 hoses with 1/2" male AG quick connect ends and a hydraulic flow restrictor to slow down the operation of your top link. Email me at Fit Rite if this sounds like it will work out for you. Should take about 15 minutes for you to have it installed and be up and running.
04-14-2012, 08:01 AM #6Platinum Member
- Join Date
- Jan 2012
- Posts
- 933
- Tractor
Does this unit have the valve that prevents drift so that if you were using a balast box or something you don't have to keep adjusting? Thanks
Originally Posted by MtnViewRanch
04-14-2012, 09:18 AM #7Super Member
- Join Date
- Dec 2003
- Posts
- 5,583
- Location
- Western Kentucky
- Tractor
- JD3720 Cab, 300X loader with 4-in-1 bucket
Unnecessary item. "Drift" is more a problem of worn hydraulics on the tractor than it is of a HTL, especially a new one. I got one made to my own specs by MtnView, it was plug-n-play. And no drift whatsoever, even when transporting half-ton bouncing loads. Everything needed to make it work off my existing John deere remotes was included in the price. If you want, ask MtnView to look up the specs on the one he made for me. He'll have no trouble cloning one for you.
//greg//USN (Ret)
Former Chinese tractor owner (x4)
Current John Deere owner
04-14-2012, 10:21 AM #8Elite Member
Advertiser
- Join Date
- Mar 2005
- Posts
- 5,888
- Location
- Tractor
04-14-2012, 10:45 AM #9Super Member
- Join Date
- Feb 2008
- Posts
- 7,736
- Location
- somewhere usa
- Tractor
- stuff
04-14-2012, 01:17 PM #10Elite Member
- Join Date
- Aug 2011
- Posts
- 2,687
- Location
- Earth
- Tractor
- Deere
I'd be going for Brian's kit as well. Although I'm not one of them, he has many happy customers here on TBN and elsewhere.
You know the hydraulic side link is very nice as well
Similar Threads
Toplink Hydraulic top link w/built in valve???
By gordon21 in forum AttachmentsReplies: 11Last Post: 06-11-2010, 04:06 PM -
Source for hydraulic side link w/ DPOCV's?
By PAB_OH in forum HydraulicsReplies: 4Last Post: 06-26-2008, 10:00 PM -
Slow hydraulics in winter
By grsr3 in forum Chinese TractorsReplies: 27Last Post: 05-01-2007, 11:31 PM -
2210 Hydraulic Top Link Solution
By CHUCKG in forum John Deere Owning/OperatingReplies: 3Last Post: 12-11-2003, 10:55 PM -
Hydraulic Top Link
By roysallis in forum Ag Tractors & MachineryReplies: 7Last Post: 07-13-2000, 08:08 AM
