Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,088
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: hydraulic problems on 2030
    Pto is operated off of trans pump psi while loader is operated off of main high pressure ft pump. Loader valve if the convertible type(open to closed/vice-verse) could have a blown internal(replaceable) o-ring(parts key #10). Technically the o-ring mentioned above and spool seals is all that's repairable on a spool valve.
    Attached Thumbnails Attached Thumbnails hydraulic problems on 2030-w6340f_________un01jan94-gif
  2. #12
    New Member
    Join Date
    Jul 2013
    Posts
    8
    Guernsey
    John deere 2030
    hi everyone looking for some advise please i have a john deere 2030 i was out topping yesterday when i picked up a tarpolen around one of the blades on the topper and the topper stopped so i thought the shear pin on the pto shaft sheared when i checked the pin it was fine so i stopped the tractor checked things over and all seemed ok started the tractor up lifted up the back arms all ok but still no pto working so i headed back for home on my way back about half a mile down the road i lost powersteering got back home lowered the topper down with the back arms and now cant lift the arms up i have lost all hydraulics no pto working no back arms and no steering any ideas thanks paul
  3. #13
    Join Date
    Jan 2007
    Posts
    7,088
    Coyote Flats,Tx
    Check frt hyd pump coupler for stripping. How long since hyd filter was changed and sump screen checked/cleaned? Which type pto continuous running(dual stage foot clutch) or hyd ind pto??
  4. #14
    New Member
    Join Date
    Jul 2013
    Posts
    8
    Guernsey
    John deere 2030
    Hi thanks for reply the coupler is fine not sure when filter was changed not sure where it is and sump screen check not sure what this is? And the pto is controlled from a leaver just underneath the steering wheel on the right hand side next to the hand throttle.
  5. #15
    Join Date
    Jan 2007
    Posts
    7,088
    Coyote Flats,Tx
    Are you 100% sure that main hyd pump shaft is turning with the engine crankshaft?? The couplers have a history of spinning on the pump shaft.Sounds as if pto is the hyd ind type. Screen(parts key #30) is accessed on RH side by hyd filter
    Attached Thumbnails Attached Thumbnails hydraulic problems on 2030-re031173_______un03nov99-gif
    Attached Images Attached Images
  6. #16
    New Member
    Join Date
    Jul 2013
    Posts
    8
    Guernsey
    John deere 2030
    Any ideas where the hydraulic filter is on this tractor ??
  7. #17
    New Member
    Join Date
    Jul 2013
    Posts
    8
    Guernsey
    John deere 2030
    Pump 100% turning with crankshaft checked oil filter spotless took the screen out was nice and clean apart from the last inch or so of the screen a fair bit of crap come out would this be enough to give me problems ? Thanks
  8. #18
    Join Date
    Jan 2007
    Posts
    7,088
    Coyote Flats,Tx
    Loader control valve could be leaking internally. Does loader have an independent hyd valve or is it controlled by tractor remote valves(SCV's)??
  9. #19
    New Member
    Join Date
    Jul 2013
    Posts
    8
    Guernsey
    John deere 2030
    Which is the loader valve please? I cracked open the 3 hoses into the front hydraulic pump the top inlet had oil the discharge port had oil but the right inlet had nothing what so ever dose this info help?
  10. #20
    Join Date
    Jan 2007
    Posts
    7,088
    Coyote Flats,Tx
    Quote Originally Posted by Paul arnold View Post
    It's been since the late 80's since I worked for a JD dealer but IIRC line #1 carries trans pump oil to frt hyd pump and line #13 carries high pressure oil to the rear. Ind loader valve would be attached to loader on RH side.
    Attached Thumbnails Attached Thumbnails hydraulic problems on 2030-l58471_________un01jan94-gif   hydraulic problems on 2030-w5316__________un01jan94-gif
Similar Threads
  1. Hydraulic Cylinder Problems on Bog Disk
    By exiled cheesehead in forum Hydraulics
    Last Post: 04-07-2010, 08:48 AM
  2. Wood Splitter hydraulic problems.
    By Adiredneck in forum Hydraulics
    Last Post: 03-17-2009, 12:40 AM
  3. Hydraulic problems.. please help
    By kcolonel1030 in forum Hydraulics
    Last Post: 10-24-2007, 11:08 AM
  4. 3054XS TLB Hydraulic Problems
    By BillA in forum Kioti Owning/Operating
    Last Post: 09-20-2006, 01:15 PM
  5. Hydraulic problems YM187
    By Whiskey in forum Yanmar
    Last Post: 07-30-2002, 09:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
