Paul arnold
Thanks do not have a loader or loader valve on this tractor would oil come out the hydraulic pump on line 13 and flow to the back end I have nothing in line 13 could this mean its the hydraulic pump on the front ? Thanks
Hi thanks for reply the coupler is fine not sure when filter was changed not sure where it is and sump screen check not sure what this is? And the pto is controlled from a leaver just underneath the steering wheel on the right hand side next to the hand throttle.
Here is an update on the original post. My control valve for my loader was bypassing internally and I switched it out with a joystick control valve. This fixed the three point raising issue. My PTO not having any power was a not a simple fix. The pump checked out to be within spec but at the far end of good. Someone had worked on the tractor previously and assembled the pto clutch incorrectly and had tweaks in the lines and some other issues stemming from not knowing what they were doing. I thought I would be lucky and this would be it. The PTO worked better but still would not hold under heavy load. I ended up installing a new pump and this completely solved the issue. My PTO operates like new and will kill the tractor under load before slipping. I warn people to fix things right. If you do not know what you are doing DO NOT GUESS. Sometimes it takes the proper tools to diagnose and repair. I am sure the pump was the issue even though it measured within acceptable limits. This is just a heads up and to let you know my experience. It helps a lot when people post the resolution to their problem. I appreciated all of the responses I received and they really helped a lot.
