Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    3
    Brighton
    John Deere 2520
    Default New tractor ended up in the pond
    Hello everyone!
    So far it has NOT been a very good day! I was cutting some trees around my pond and pulling them to the burning pile with my John Deere 2520. On the LAST one I put the tractor's emergency brake on and got off to hook up the log. Apparently I did not have the emergency brake fully locked engaged because it popped out when I walked half way down the hill. I wasn't able to hop on and set the brake so my tractor went for a swim.
    It sat in the pond for about 20 minutes. The good news is the engine did not go under water, and the transmission was relatively cool since I had only ran the tractor for 15- 20 minutes.
    My question is, does the transmission have a vent tube, and if so where is it? I have Googled for the answer but have been unsuccessful. I'm worried that it might have went under water.
    Do you think everything will be okay? I JUST changed the transmission fluid last week...Im really hoping no water got in.
    I attached a picture that shows how far it went in. At least it is clean now.
    Thanks!
    Attached Thumbnails Attached Thumbnails New tractor ended up in the pond-20120421_154151-jpg
  2. #2
    Super Member bp fick's Avatar
    Join Date
    Aug 2009
    Posts
    5,716
    Beaver Creek, Northern Michigan
    Kubota BX2360
    Default Re: New tractor ended up in the pond
    Many times, the filler cap serves as a vent as well. I'd change the filter and fluids in the trans and front axle fluid as well. Fluid is cheap. Problems are not.
    Consider the new materials cost as penance.
    BP
    "Some chickens, some gardens and a Kubota."
  3. #3
    Platinum Member pjbci's Avatar
    Join Date
    Feb 2012
    Posts
    712
    Summit. Ms
    JD 4840, 450j, 310, komatsu D31px22, IH 1486, MF 135, MHF TO35
    Default
    Just check it and see if trans oil is milky before going to the expense of changing it.
  4. #4
    Veteran Member General Lee's Avatar
    Join Date
    Oct 2009
    Posts
    1,323
    Mid-Atlantic
    Kubota, L4400, BX1870
    How'd you get her out. Did you wade in a drive that beast out in 4wd?
    Kubota L4400 - Land pride rear scraper blade, 6 foot landscape rake, 72'' Frontier Box Blade, Land Pride 60'' finish mower, Land Pride Q/A pallet forks, County Line Carryall built to haul and loaded R-1's
    Kubota RTV500
    Kubota BX23S
    Previous Tractors: 1978 B7100, 2009 B3200, 2013 BX1870
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,927
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    Sorry for your dilema. I had a similar run-away once, with an attempt to jump on to stop it. Wasn't good.
    I would have waded in and started it, to see if it would drive right out. Looks like you are letting it set in water, or is it out already.
  6. #6
    Super Star Member Thomas's Avatar
    Join Date
    Apr 2000
    Posts
    17,312
    Lebanon,NH.
    Kubota L2800HST w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
    Glad no damage etc...whew,I would replace all fluids & filters than check after good work out just make sure.
  7. #7
    Veteran Member buck12's Avatar
    Join Date
    May 2006
    Posts
    1,216
    NW Mississippi
    Mahindra 2615
    Default
    Don't feel too bad. My neighbor and I both have put our John Deere lawnmowers in our shared pond.
  8. #8
    Join Date
    Dec 2011
    Posts
    102
    Winston Salem, NC
    Kubota l39
    My son put our ZD21 in the pond.All I could see was orange way down at the bottom.Thirteen feet deep. Oh well, he's a good kid.
  9. #9
    New Member
    Join Date
    Apr 2012
    Posts
    3
    Brighton
    John Deere 2520
    I feel so much better knowing I am not the only one! lol
    Lee, I thought about attempting to drive it out, but since it was so close to the top of the transmission I didnt want to risk digging it even deeper. I did get it out. I am very lucky that my neighbor was home and he has a bigger John Deere than I have.
    Beenthere, I attempted the "jump on and hit the brake" move too...obviously it didnt work. Looking back I should have just turned the wheel!! It was running so it had power steering! I guess my mind wasn't working at that moment...It was busy thinking " OH !@#$, there goes my $20K tractor!!!"
    For those interested, I did find the vent tube. It is on the top of the transmission near the rear of the tractor. There is a rubber hose that goes from a metal nipple towards the front of seat where it attached to an upside down plastic "bowl". I pulled the hose and there was a couple water droplets in it, however there was a lot of dry dust as well. It looks like it may have sucked up a tiny bit when the tractor "splashed". I am going to go ahead and change the hydraulic fluid just to make sure. I love this tractor way to much to take any chances!
  10. #10
    New Member
    Join Date
    Apr 2012
    Posts
    3
    Brighton
    John Deere 2520
    Quote Originally Posted by Dadof3 View Post
    ouch! I came to the conclusion today that I am not letting my son mow around the pond..lol
    If this would have been just a few feet over I would have been watching green sing to 16 feet!! All in all I am pretty lucky!
Similar Threads
  1. Pond drain/breach question
    By scesnick in forum Rural Living
    Last Post: 04-05-2012, 02:56 PM
  2. My Pond Project
    By ETD66SS in forum Projects
    Last Post: 03-29-2012, 10:19 AM
  3. Pond cleaning questions (long)
    By RonR in forum Projects
    Last Post: 12-27-2003, 01:08 AM
  4. The Fish Pond . . .
    By Libertine in forum Related Topics
    Last Post: 10-05-2003, 03:37 AM
  5. Help with new pond
    By Rowski in forum Projects
    Last Post: 07-27-2002, 05:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
