Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    2
    michigan
    jd 300
    Default Older JD 300 diesel backhoe and loader starting
    I've inherited this tractor from my dad. I have a silly question. Below the key/ignition there is a toggle the clicks into 3 or 4 different positions. Is this some type of choke? Unable to track down what this does - when it is in one of the positions the tractors makes an awful noise when I try and start it. Having troubles starting it this spring and was hoping this lever may be some type of choke. Battery charge on it right now to make sure everything is up and charged.
    Not sure of the year - he's had it since mid 70's for sure - and purchased it used. It is a diesel - not sure if some type of glow plug either.
    Any assistance is greatly appreciated.
    Thanks
  2. #2
    Join Date
    Dec 2001
    Posts
    1,351
    Maryland
    Default Re: Older JD 300 diesel backhoe and loader starting
    The switch you mention is actually the light switch. It shouldn't have any effect on starting... unless someone has changed things around. The 300 did not have any glow plugs.
    Attached Thumbnails Attached Thumbnails Older JD 300 diesel backhoe and loader starting-t9848__________un01jan94-gif
  3. #3
    New Member
    Join Date
    Apr 2012
    Posts
    2
    michigan
    jd 300
    Thanks so much - that's the switch -
    Could be I turned on the light and that pulled the power from the battery.
    Appeciate your help!
Similar Threads
  1. john deere 300 loader backhoe
    By pago52 in forum Hydraulics
    Last Post: 04-21-2012, 11:23 AM
  2. Loader Procedure for removing JD 300 ind. loader?
    By jeciron in forum John Deere Owning/Operating
    Last Post: 03-01-2011, 07:05 PM
  3. 110
    By joecdeere in forum John Deere Buying/Pricing
    Last Post: 05-08-2002, 09:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
