Results 1 to 5 of 5
  1. #1
    Veteran Member yelbike's Avatar
    Join Date
    Nov 2011
    Posts
    1,643
    Near Winnipeg, Mb, Canada
    John Deere 2305, 2320,Z465
    Default How to remove sheave/ pulley???
    I'm trying to remove the pulley/sheave next to the deflector on the right side.
    Is it possibly reverse thread? Whats the proper way to get it off??
    I'm working on a 62d mmm for my JD2320.
    Thanks in advance for the help!!!
    Carefull what you aim for, Aim for nothing and you will achieve it with amazing accuracy.
  2. #2
    Platinum Member chevy's Avatar
    Join Date
    Mar 2003
    Posts
    627
    East Central, Indiana
    John Deere 4120 John Deere 1026R
    Default Re: How to remove sheave/ pulley???
    The threads are right hand. The service manual says to use a impact wrench. That worked on one deck but not another. The second deck had set outside for a long time. I had to buy a large spanner wrench to hold the pulley, use penetrating oil & use a socket on a breaker bar to get the nut loose.
    John Deere 2025R, H130 Loader, 62D Mower Deck, John Deere 655 Tiller, Front Grader Blade, Frontier LR2072 Landscape Rake, Frontier Pallet Forks, Woods GB60 Box Blade
    John Deere X739 AWS 4x4 with 60HC deck.
    John Deere 825i Gator
    John Deere Tractors I have owned in the past.
    425 AWS, 455, 4400, 2210, 4710, 2320, 2720, X475, 1026R, 4120
  3. #3
    Join Date
    Jan 2005
    Posts
    98
    Indiana
    JD2305, 1948 B.F. Avery Model V
    yelbike,
    The sheave nuts can be a bear to get off sometimes. I use the following tricks usually in combination for difficult nuts.
    Stand and brace the deck on edge then,
    1) Keep the pulley on the sheaves. Place a block on one of the other blades to help provide tension on the sheave through the pulley.
    2) Put a breaker bar on the underside blade nut and maintain slow steady pressure.
    3) If you are careful you can slide a large flat blade screwdriver or equivalent through one of the two holes in sheaves and lodge it into one of the recesses around the base of the spindle assembly. Such that holding the end the screwdriver provides leverage to prevent the sheave from spinning. The longer the tool, the better.
    Lastly, put the longest breaker bar you have on the sheave nut and apply force in short rapid motion (e.g. Or tap with mallet).
    I don't usually have to do all three, but I usually attempt to remove the nut after each step. Once I got the nut off, I have only needed to use steps 1 or 1+2. Obviously, a large spanner wrench is ideal if you have one.
    JD2305 w/ 62MM, 200CX, Markham toothbar, RB1060, sprayer, Ballast,
    1948 B.F Avery (Model V)
  4. #4
    Join Date
    Nov 2011
    Posts
    1,643
    Well I got it done. I wrapped a large rope around the sheave and DW was able to hold it while I used a large breaker bar to break it free. Thanks for the suggestions!!
    Attached Thumbnails Attached Thumbnails How to remove sheave/ pulley???-plb-pics-095-jpg
  5. #5
    Veteran Member megotatractor's Avatar
    Join Date
    Feb 2004
    Posts
    1,053
    New Richland, Minnesota
    JD 2210
    Darn sheave nuts. I have had them all off. The only result I got from an impact wrench was to have the blade bolts come loose and then the blade fell off and the sheave nut was still nice and tight. The only way is to stand the deck on edge, use a long breaker bar, a firm gloved hand on the blade and lots of muscle. An assistant if available.
Similar Threads
  1. HELP - Cub Cadet RZT pulley removal
    By JimGrey in forum Cub Cadet L&G
    Last Post: 03-25-2012, 04:45 PM
  2. How to remove axle out of 5300?
    By exiled in forum John Deere Owning/Operating
    Last Post: 12-27-2011, 07:51 PM
  3. how do you remove the front pulley
    By 2diamondfarm in forum Parts/Repairs
    Last Post: 11-04-2011, 05:10 PM
  4. RFM metric spindle pulley
    By jcliburn in forum Parts/Repairs
    Last Post: 08-04-2010, 09:36 PM
  5. Replies: 4
    Last Post: 08-30-2007, 03:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
