Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Feb 2012
    Posts
    777
    Staunton, VA
    John Deere 3038E
    Default Weird Thing - Link Broke
    The left lift link on my JD 3038e broke this afternoon - at a time when I was doing FEL work and had nothing on the hitch. The lift link is the bar from the hydraulic arm down to the draft link, the bar that is a third of the 3-pt hitch.
    I was busy and didn't notice the break I guess, and backed up with a few vines in my bucket. The back of the tractor rose up - the same effect you get when you try to lift more than the tractor can handle. I lowered the bucket and - tho it took a few seconds for the left rear to drop- I didn't notice it for a few moments - then heard a dragging noise and checked.
    The draft link had dropped and, as I backed, it had lifted up the back rear wheel and wedged forward.
    I studied the situation - since I was a mile from anywhere, then removed the sway chain and slowly ran forward. The link lifted the tractor again and came out where it was supposed to be. I wired it up until I was finished.
    The lift link broke at the weld, so I can only assume it was a defect - although I have used a box blade and rotary cutter on it recently without problem. Got 35 hours on the tractor.
    I'll drop by the dealer tomorrow.
  2. #2
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    Default Re: Weird Thing - Link Broke
    Quote Originally Posted by DKCDKC View Post
    I did a similar thing with my JD970. I had a rear blade on the tractor at the time. I was backing up in a road ditch (fairly wide) and pushed one corner of the blade into the ground.
    Wasn't going more than 2-3mph and that was enough... broke the lift link between the rockshaft and the lower draft arm.
    Think it was ~$170 for a replacement - !
    Nonetheless, I ALWAYS look behind me when backing and NEVER assume I'm either too far or too close to hitting something - I KNOW where the implement or the 3pt arms are!
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  3. #3
    Join Date
    Feb 2012
    Posts
    777
    Staunton, VA
    John Deere 3038E
    What was so weird about breaking this link was that the hitch was completely empty... But had been used before.
    I have had issues with my last two tractors with the snap pins coming loose and dropping with various implements - so I have gotten in the habit of looking back fairly often when anything is on the hitch.
  4. #4
    Join Date
    Feb 2012
    Posts
    777
    Staunton, VA
    John Deere 3038E
    Whatever the cause... My dealer couldn't figure it out either... But replaced it under warranty.
    'Course just going to the dealer can be expensive. They put so many nice toys (attachements, JD doodads, etc.) in the lobby or out front, it's hard to get in or out without another investment. But I made it this time.
  5. #5
    Join Date
    Dec 2009
    Posts
    1,907
    S. W. Virginia
    Kubota B3200, Ford NAA, IH 454D, Case 1845C
    Consider yourself very lucky, we used to have a JD 4400 that this happened to. The 3pt arm dropped down (while mowing with nothing on the 3pt) and when it backed up the arm went up under the tractor like you described and snapped the rear axle housing. A very expensive repair.
    Kubota B3200
    Ford NAA Jubilee
    International 454D
    Case 1845C skid steer
    JD 265
  6. #6
    Join Date
    Feb 2012
    Posts
    777
    Staunton, VA
    John Deere 3038E
    Fortunately on the 3038e the arm could only wedge against the tire. It didn't have the position to press on anything else as far as I could see. But it could have rolled the tractor had I had the bucket loaded.
  7. #7
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    I see the 3038e has side links, although - in the tractor manual - they look somewhat insubstantial. On all the tractors I've owned, side links could be adjusted to prevent the lift arms from striking the inside of the tires? If this is true for the 3038, then you should shorten them accordingly to prevent this from happening again.
    //greg//
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  8. #8
    Join Date
    Feb 2012
    Posts
    777
    Staunton, VA
    John Deere 3038E
    The 3038e does have side links and, to me, they seem pretty substantial. The problem is that when the lift link breaks, the lower draft link drops straight down. If you then back up, it catches the ground and is forced under the tractor toward the tire. The side link prevents the link from going toward the center of the tractor. It is not and could not be a solid bar to prevent it ever going toward the tire. The two side links working together prevent the implement from swaying. Anyway, when the draft link is levered under the tractor, the geometry of the side link changes and it allows the bar to get under or wedged against the tire. Fortunately, it did not press against anything that would break.
  9. #9
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    Ah, I didn't understand the sequence as stated in your original post. But really, that too is avoidable. I've got quite a varied assortment of TPH implements. Every one (that I can't lift by hand) has lift pins that are at least 6" above ground level. I find no need to have the lift links adjusted to where they're at or near ground level. They're adjusted to no higher than pin level, and never ever even get close to ground contact.
    And FYI, my 3720 has pin-adjustable semi-rigid side links. You might consider checking to see if they're compatible with the 3038 mounting points.
    //greg//
    Attached Thumbnails Attached Thumbnails Weird Thing - Link Broke-3720-side-link-jpg
    USN (Ret)
  10. #10
    Super Star Member
    Join Date
    Aug 2001
    Posts
    14,977
    Southern Wisconsin, USA
    JD_4x2_Gator, JD_4300, JD_X485, JD_425, JD_455, JD_110
    DK
    Do you have a pic of the broken link? I'm curious where it broke. thanks
    I assume it is the item #36 shown here.
    Attached Thumbnails Attached Thumbnails Weird Thing - Link Broke-3038e_3ph_link-jpg
Similar Threads
  1. My CCM top link broke!!!!
    By actionaj in forum Kubota Owning/Operating
    Last Post: 11-14-2011, 07:21 PM
  2. BX2200 Top Link Problem
    By Scaper in forum Kubota Owning/Operating
    Last Post: 08-15-2003, 11:12 AM
  3. Replacement Top Link Bx2200???
    By NY_Yankees_Fan in forum Kubota Owning/Operating
    Last Post: 05-25-2003, 10:53 AM
  4. top link
    By lblair in forum Attachments
    Last Post: 11-04-2001, 08:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
