Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    1
    Choctaw, OK
    430 John Deere
    Default 430 baler tying problems
    Hi, I'm Linda. I turned to this website for help since my husband is too stubborn. He ended last season with the baler working fine. This season it ties over and over in the same place and won't cut. He has replaced parts, greased and about everything that you would normally do. If you reply I think your comment will go to his email. Any suggestions?
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,237
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 430 baler tying problems
    Linda
    The tying mechanism on a JD 430 rd baler is a little complex. First tell your hubby to be sure all 5 springs in attached photo are intact and attached correctly. Hay/debris can build up under parts key # 14 keeping spool valve from shifting allowing twine arm to move to the RH but not return to LH side to put twine on bale and cut twine. Also rust/debris on spool shaft of valve can cause problems. Back when 430's were new I sold and delivered them. Your hubby can feel free to call me at 8one7*five1seven-1five9zero and I will try to help him. Also I baled many bales with a 430 before I upgraded to a 435,then a 466,then a 467 in my 20+ yr custom hay baling career.
    Attached Thumbnails Attached Thumbnails 430 baler tying problems-ep6005_________un01jan94-gif
  3. #3
    New Member
    Join Date
    May 2012
    Posts
    1
    Lascassas, TN
    JD 2350, 6210
    I am pretty familiar with the 430. Does it try to tie when the bale is about three feet around? This is a very easy and cheap fix. On the right hand side, open the door. Look below the twine box. Find an arm made from about one inch bar steel kind of behind the twine arm pump. It will have a slanted angle cut towards the front of the baler and the rear of the bar goes...who knows where. It is the bar that the manual tie rope connects to. Anyway, find that bar, There should be a little spring about 2-3 inches long holding pressure on the bar. It should hold pressure to make sure the bar slides back and latches after the gate closes. If it is gone or sprung, your baler will want to tie just as the bale starts forming. Look in your operators manual for pictures in this area showing the spring. It is hard to describe something that is probably not there.
  4. #4
    Join Date
    Jan 2007
    Posts
    7,237
    Coyote Flats,Tx
    levijames
    A 430 can tie a 3 ft diameter bale every time even if spring you referred to is attached and not sprung if tying mechanism fails to reset because of an obstruction when tailgate is closed after bale is ejected.
  5. #5
    New Member
    Join Date
    Sep 2011
    Posts
    11
    Case 930CK
    I just bought a 430. I roll up around 1k bales per year
    is it OK to pressure wash the whole thing, including inside the doors to remove debris and chaff?
    Mine needs a good cleaning, but appears to be in good shape.
  6. #6
    Join Date
    Jul 2003
    Posts
    631
    under the elephant\'s tail [ ontario can.]
    john deere 3130, universal
    I would check to make sure that the spring bars that hold the hay down against the strippers isn't bent and catching the string as it travels across on it's way to the cut off. Something is stopping the string from aligning against the left side of the bale and lining up with the blade mechanism.
  7. #7
    Join Date
    Jan 2007
    Posts
    7,237
    Coyote Flats,Tx
    Quote Originally Posted by nanuk View Post
    High pressure washing can lead to brg failure from water being pushed past brg seals. Blowing off with air is better choice for cleaning.
  8. #8
    New Member
    Join Date
    Sep 2011
    Posts
    11
    Case 930CK
    thanks Tx Jim
    that makes sense to me.
    I learned to bale on a 605C. Now am moving onto a 430jd. it is like going from counting on fingers to using a computer.
    this will be an interesting season.
  9. #9
    New Member
    Join Date
    Sep 2011
    Posts
    11
    Case 930CK
    subscribed
  10. #10
    New Member
    Join Date
    Jul 2017
    Posts
    1
    Union, Ms
    JD 5410
    Good Afternoon, I found this old post about JD 430 tying problems. I have a 530 doing a similar thing and I hope you can help or point me in the right direction. In the thumbnail you had showing the parts break down, #21 is not returning to the home position back under #14 after I dump a bale, I have to manually pull #21 forward towards the tractor about 1/4 inch before I start a new bale. I have replaced the springs, changed the filter, and check the fluid level. If I reset #21 back under #14, the tying arm will travel correctly, however I also have to apply pressure to the arm when it reaches the RH side to make it click and then travel back to the LH side. It will start to pull the knife blade down, but does not seem to have enough pressure to complete the knife cut. any ideas? thanks in advance Carl
Similar Threads
  1. New Vermeer 5410 Rebel Baler
    By HayDR in forum Ag Tractors & Machinery
    Last Post: 10-22-2012, 09:20 PM
  2. 273 NH Square Baler problem w/knot tying
    By KentKeller in forum Parts/Repairs
    Last Post: 03-18-2012, 01:26 AM
  3. JD 336 Baler Problems
    By sadair in forum John Deere Owning/Operating
    Last Post: 02-16-2011, 08:55 AM
  4. IH 47 Baler
    By Jim at NineTrees in forum Ag Tractors & Machinery
    Last Post: 11-17-2010, 06:48 PM
  5. Heston Hay Baler crapped out. Why?
    By ClemBert in forum Attachments
    Last Post: 07-31-2007, 07:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
