Results 1 to 7 of 7
05-21-2012, 09:50 AM #1New Member
- Join Date
- May 2010
- Posts
- 19
Which size BB for 955
I'm looking to purchase a BB this week for my 955. I've looked at a bunch of threads but I can't figure out if I should be getting a 5ft or 6ft BB. I was leaning towards a 5ft blade. Does that sound about right?
Thanks.
05-21-2012, 10:17 AM #2Super Star Member
- Join Date
- Aug 2001
- Posts
- 11,474
- Location
- Upper Midwest USA
- Tractor
- JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
Re: Which size BB for 955
Sounds right, as long as it reaches the outside width of your rear tires.
11-13-2012, 11:25 AM #3New Member
- Join Date
- Aug 2008
- Posts
- 13
- Location
- Riverside, IA
- Tractor
- John Deere 955
What did you end up with? I just bought a 5' used BB for my 955 and wanted something that would cover the 5' width of the rear tires. I was concerned I wouldn't have enough power/traction for anything larger (I have turf tires). Wondering how it worked out for you? I've attempted to attach a photo...
11-13-2012, 03:34 PM #4
For me and the type of ground I use it on, the 60" is just right. I have R1s set in the wide position.
11-13-2012, 08:35 PM #5
60" is what I use on my 855; works well there also.
I like to play in the dirt....
Satoh Beaver w/Blackhawk loader & hoe.
JD855 w/stuff.
11-13-2012, 09:20 PM #6Silver Member
- Join Date
- Apr 2011
- Posts
- 229
- Tractor
- John Deere 2720
I agree. The 955 could handle the 6ft blade but the 5ft will be more manueverable. I had a 6ft on my 2720 for a short while as it was left over from my Ford 9N. It was a bit unweildy. I sold it and got a 5 foot and am much happier.
The only thing you need to ask yourself is do you plow a lot with the blade angled? If so, you want the blade to still cover the width of the tires while angled and you might need a 6ft blade to do that.
11-13-2012, 10:54 PM #7
Since box blades don't angle, the point is moot.
For my grader blade, I went 6ft though I wanted 5ft, I got the 6 for the same price as they didn't have the 5ft in stock when I got there (they said they did earlier). Having gotten 6ft I am glad of it. Did the same when buying a landscape rake so I can angle them fully and have my tread path covered.I like to play in the dirt....
JD855 w/stuff.
Similar Threads
B3300 FEL Bucket vs Tire Size
By Tompet in forum Kubota Owning/OperatingReplies: 6Last Post: 04-01-2011, 12:51 PM -
Proper size box blade for B3200 (heavy commercial use)
By Verticaltrx in forum AttachmentsReplies: 4Last Post: 08-16-2010, 10:38 AM -
Grading Rear Blade or Box Blade for project, size?
By Qhorse in forum John Deere Owning/OperatingReplies: 10Last Post: 09-14-2009, 09:16 PM -
socket size for Cat. I lower link pin. 7/8 inch diameter
By splotkin in forum Kubota Owning/OperatingReplies: 8Last Post: 06-21-2009, 08:20 PM -
Tractor Sizing 410 Bucket Size
By Bertilak in forum John Deere Buying/PricingReplies: 5Last Post: 08-31-2002, 09:14 PM
