M Johnston
The three point hitch on my Dads (he's 80 yrs old) JD850 will travel up or down, but will not stop at any other point. There is or was a small lever under the seat which I strongly suspect provides adjustment to the lift, however I broke it off in an effort to free it up (has been used to spread fertilizer). Can the valve that is adjusted by this lever be easily be taken off inorder to replace the lever? It is held on by 4 bolts, has one hyd line on it and other plugs. It is one thing if I can take the valve off, replace the lever with internal linkage by removing a snap ring and quite another if detailed adjustments have to be made. In addition, will this solve the preceived problem with the lift? Thanks for any help.
