Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jun 2012
    Posts
    3
    Le Claire, Iowa
    Deere 1026r
    Default 260 backhoe hose problems
    One of the hydraulic hoses on 260 backhoe mounted on 1026r runs over top of left footrest. Dealer called Deere engineering and they said yep. My left foot accidentally uncoupled hose yesterday
    Anybody have this issue?
  2. #2
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    655
    WV,Preston County
    JD 1026R
    Default Re: 260 backhoe hose problems
    WHY !! over the top of rest foot step.. Yea my goes back behind and close to footrest but not where I 've ever stepped on mine to disconnect lines.
    Sure you had hose completely latched .... Yes I've stepped on my hoses but never to the point of hoses disconnected.
    I've got a 2305 with BH ,just wondering mine has a bracket to hold hoses to help keep them back behind your foot so wondering ,if yours has a bracket to hold your hoses back behind your foot.
    Called a Support about 6-10" long lines from the BH comes up through the support ...Item # 39
    Good luck
    Attached Thumbnails Attached Thumbnails 260 backhoe hose problems-mp38708________un06nov06-gif
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  3. #3
    New Member
    Join Date
    Jun 2012
    Posts
    3
    Le Claire, Iowa
    Deere 1026r
    I have attached a photo showing the location of the hose covering the left foot rest. Surely the hose is installed incorrectly??
    Attached Thumbnails Attached Thumbnails 260 backhoe hose problems-img_6756-jpg
  4. #4
    Join Date
    Mar 2010
    Posts
    82
    VA
    JD 1026R
    What a bunch of people do (I learned it from others) is to place the hoses a little differently... Basically from the picture you just posted I would uncouple the connector you would be stepping on and couple it just inside of the coupler with the hard 90deg bend on it. This will keep that 1/2 loop of hose (the one going out over the tire and back) back up tight against the machine.
    If the hoses won't go that way easily then park the machine, de-pressurize the hydraulics, and loosen the nuts nearest the hose you need to twist in order to get things into place. This will allow you to re-position the hoses to get them to route properly. Once things sit right then you re-tighten everything securely and off you go. It goes without saying that if you aren't comfortable with hydraulics then please get your dealer or a friend who is comfortable to do it and never check for leaks with your hands... just google "hydraulic injection injury" to see why.
  5. #5
    New Member
    Join Date
    May 2012
    Posts
    18
    Central MA
    2012 JD 1026r
    Quote Originally Posted by Burtcg View Post
    Easy fix: disconnect the offending hose and run it behind the other connected hydraulic hose and reconnect.
  6. #6
    New Member
    Join Date
    Jun 2012
    Posts
    3
    Le Claire, Iowa
    Deere 1026r
    Dealer came out and brought out a wore hose guide and bolted it to foot rest of backhoe and it keeps house out of the way.
Similar Threads
  1. BackHoe Hose Connections
    By TO_Bud in forum New Holland Owning/Operating
    Last Post: 07-07-2010, 04:16 PM
  2. Backhoe blown hose for backhoe
    By johnnylight in forum New Holland Owning/Operating
    Last Post: 09-23-2009, 05:16 PM
  3. Backhoe Hydraulic hose problem with 930 Backhoe
    By DCJL in forum New Holland Owning/Operating
    Last Post: 09-15-2008, 01:11 PM
  4. Branson rear remotes
    By taxidermist1 in forum Century & Branson
    Last Post: 05-19-2006, 12:29 PM
  5. 110
    By joecdeere in forum John Deere Buying/Pricing
    Last Post: 05-08-2002, 09:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
