Results 1 to 6 of 6
  1. #1
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,808
    South West MI
    John Deere 2030, John Deere 6415
    Default Installing a MultiCoupler on a JD 640 SL Loader.
    After adding the third function to my JD 640 SL loader it had SIX quick couplers to deal with when removing/attaching the loader. I decided to "bite the bullet" and change to a MultiCoupler.
    The hardest part was paying $500 for the MultiCoupler, then $50 for adapters. My 640 hoses were JIC female swivel. The Multicoupler was male ORFS. D.H.H. had the adapter, part nhumber FS6504-08-08. JD wanted about $50 for the mounting bracket, so I made my own.Installing a MultiCoupler on a JD 640 SL Loader.-bracket-001-jpg
    The handle really stuck out so I straightened it. Installing a MultiCoupler on a JD 640 SL Loader.-bracket-002-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-tractor-009-jpg
    pclausen posted a picture of his new JD 5085M with H260 loader. His MultiCoupler was turned 90*Installing a MultiCoupler on a JD 640 SL Loader.-5085h260-3-jpg
    I decided to make a new bracket to turn my MultiCoupler 90*. I determined it had to be 3/4" thick and I could use socket head allen screws to attach it to the MultiCoupler. There was enough room to bolt it to the loader mount from the inside. I got M10 button head screws for this. I made a wood trial piece. I mounted it to the Multicoupler and determined where it would mount to the loader mount. I had to take into consideration the square pin that hold the loader boom to the loader mount, both for pin removal and storage. Next I built an aluminum mount from my wood pattern. I did not have a counterbore so I ground a drill to cut a flat bottom for that (might have only worked since I was using aluminum). I drilled and tapped three holes form the M10 button head screws. I transfered these holes to the loader mount and drilled them. Installing a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-011-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-004-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-003-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-005-jpg
    Before the MultiCoupler stuck out about 9 inches. Now it sticks out about 5 inches. The handle hit the hoses when it was closed so I had to rebend the dogleg in the handle. JD "H" series loader have a valve in the boom cylinder head end hose. I installed a valve the first time. I had to reverse the handle so the square loader attaching pin could be removed.Installing a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-001-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-006-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-009-jpgInstalling a MultiCoupler on a JD 640 SL Loader.-jdmulticoupler-010-jpg
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  2. #2
    New Member
    Join Date
    May 2013
    Posts
    20
    Lowell, MI
    Massey Ferguson TO35
    Default Re: Installing a MultiCoupler on a JD 640 SL Loader.
    Wondering if this multi coupler could be made to work for hitching remote hydraulic lines from an implement to the tractor? Thinking about making bracket on rear of tractor to hold the multi coupler. I'm trying to help a farmer who has severe hand arthritis and cannot grip hydraulic hoses from his implements to connect to hydraulic ports. From your pictures, it appears he could operate the lever and connect up to 4 hoses at once with good arm strength. Thoughts?
  3. #3
    Elite Member SSdoxie's Avatar
    Join Date
    Jun 2010
    Posts
    2,527
    Cumberland Plateau, TN
    Bobcat CT225
    This is setup for hooking and unhooking the same attachment/implement. Using for various attachments would need the base connection plus a detachable head for each implement & hose configuration.
    Dennis
    CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
  4. #4
    New Member
    Join Date
    May 2013
    Posts
    20
    Lowell, MI
    Local JD dealer said I could buy multiple "implement" heads to go with the tractor base. I'll need to fabricate a bracket for the back of the tractor so it does not interfere with 3-point implements. Then I think I'll use some short hose connections from the remote ports to the multi-coupler base. It looks like a complete 3-function multi-couple unit will cost around $770 plus stub hoses and fittings and bracket fab.
  5. #5
    Join Date
    Aug 2010
    Posts
    3,808
    South West MI
    Quote Originally Posted by DWTools View Post
    If you have a suitable mounting position this would work. Another advantage is hoses would be correct position every time.
  6. #6
    Join Date
    Aug 2010
    Posts
    3,808
    South West MI
    I have an extra multi-coupler, PM sent
Similar Threads
  1. JD 640 front loader 1999 help
    By stonz22 in forum John Deere Ag Tractors
    Last Post: 10-05-2014, 10:37 PM
  2. Buying Advice Request advise on 1954 Ford 640 with loader please.
    By donb2 in forum Buying/Pricing/Comparisons
    Last Post: 12-04-2011, 08:43 PM
  3. JD 640 loader skidsteer possibility
    By Maka in forum John Deere Owning/Operating
    Last Post: 02-01-2007, 01:53 PM
  4. installing a loader
    By mitch_lojek in forum Attachments
    Last Post: 10-08-2005, 03:36 PM
  5. 640 Loader
    By Tinkerer in forum General Vintage Tractors
    Last Post: 03-01-2004, 06:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
