Results 11 to 20 of 20
06-27-2012, 12:53 AM #11
Thank you for the advice to check images on Google images! This image is from Google and exactly opposite of my blades.
Only your DOG really knows who you are. Pray it never learns to talk.
06-27-2012, 08:33 AM #12New Member
- Join Date
- Feb 2012
- Posts
- 2
- Location
- RI
- Tractor
- bx24,Ford 2110, JD 4400
Re: What do you mean its running BACKWARDS!
I wonder if the original owner had a tractor with a counter rotating PTO. I had a Satho Beaver that was counter rotating.
06-27-2012, 09:08 AM #13Super Member
- Join Date
- Feb 2006
- Posts
- 6,756
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Maybe those tines were sharpened on both sides and meant to be turned around when dulled by use. I have found it unecessary to ever sharpen tines. Even tho blunted by use they continue to work well. What seems abnormal in the picture is that 2 tines appear to be cutting side by side together, rather than staggered rotationally as would smooth out the action.
larryThis side of 40
JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
IH37 Baler, Hesston Haybine, JD Rake
Bushog, Flail,
SK Tilt Tatch
, KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
06-27-2012, 03:48 PM #14
I don't know about that tiller specifically, but tillers do exist that rotate against travel. Most large construction reclaimers rotate in this direction and actually do a better job because the material does not pass theough until it has been significantly broken down. The only downside is that it takes more horsepower because you are pulling against the grain. I would bet that if you had the teeth installed in the correct direction you would love it.
MY2012 John Deere 5083e-563 FEL, 2008 CAT 272C with 60" Bradco Mulching Head
06-27-2012, 03:55 PM #15Bronze Member
- Join Date
- Jun 2008
- Posts
- 90
- Location
- Cape Breton, Canada
- Tractor
- Kubota B7510
Here's a little write up about the two different rotations.
Counter ( CRT ) vs. Forward ( FRT ) Rotating Tiller Information
06-30-2012, 08:16 PM #16
The back side of the tines are flat, not meant to be sharpened. I've reversed the blades now, but I have to weld the broken support arm before trying again. The arms are bolted together just before the upper arm support. The vibration caused one bar to brake at the bolt hole. Simple fix it it was another opportunity to show the wife why I NEEDED a welder. She always said, you never needed one before. That argument was ended the day I WELDED her bird feeder back together..
Originally Posted by SPYDERLK
They just don't get it, THESE ARE NOT TOYS!!!!!!!Only your DOG really knows who you are. Pray it never learns to talk.
06-30-2012, 08:31 PM #17
Dennis
CT225 w/7TL QA FEL, 60"tooth dirt bucket, 68" smooth bucket, Pallet Forks, Bale Spear. Hydrualic top llin, QH, 48 RC, 60" tiller, Angle blade, Landscape rake, Carry-all, Post hole auger.
07-02-2012, 05:50 PM #18
Ok, the blades are now rotating in the proper direction and HOLLY CRUD does this thing churn the soil!!!!
It also throws up one Heck of a dust cloud! I may have to sell it!!!! ;0)Only your DOG really knows who you are. Pray it never learns to talk.
07-05-2012, 02:32 AM #19Silver Member
- Join Date
- Jan 2012
- Posts
- 168
- Location
- Jacksonville in S. Oregon
- Tractor
- for Cristmas 2011 found used Joh Deere 670 w/ 40 hrs and options
I'll give you $100.00 just because I feel sorry after all the trouble you've had with it. Ok if we cant make a deal can a barrow it
Originally Posted by Dogtrainer
Glad to hear you got it sorted out.
Good luck and good gardening.
RoNRon JD 670
Found used JD670 with 40 hrs barned with FEL, 5' Rake, 7' Blade, 9" X 3' Rankin Auger.
Have added Box Blade, RM, Forks, plus some blood sweat and tears.
07-08-2012, 09:10 AM #20
Similar Threads
bcs 201 tiller tines running backwards
By rl3fan in forum 2-Wheeled TractorsReplies: 3Last Post: 05-14-2012, 07:53 PM -
Does running mig/shielding gas penetrate deeper than running flux core?
By super55 in forum WeldingReplies: 12Last Post: 02-10-2012, 09:23 AM -
Oil & Fuel Diesel running backwards
By Dan_Ives in forum John Deere Owning/OperatingReplies: 14Last Post: 08-20-2010, 03:06 AM -
4400 running backwards
By simonmeridew in forum Kubota Owning/OperatingReplies: 24Last Post: 01-04-2008, 11:39 PM -
Backwards running woods RFM?
By jaybirdt in forum Grey Market TractorsReplies: 15Last Post: 03-27-2006, 03:48 PM
