Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    Join Date
    Apr 2004
    Posts
    798
    Quebec
    Kubota MX 5000
    Default Re: I think I screwed up - Tires R1 vs R4
    Quote Originally Posted by s219 View Post
    Good for nothing? They are about the best tire choice for loader work, which is why backhoes and other construction equipment comes with variations of that type of tire.
    If your just considering turf-friendliness and farm-traction, then the R4s could be considered a mediocre compromise. But there are many other factors to consider.
    Bought a used MX5000 with R4 5 years ago, its main task is logging and those tires really shine out there. They are more puncture resistant, they are also more stable due to their wider stance and they wont rut those logging paths quite as much as R1 when its wet.
    They are perfect for my uses_ logging, FEL work and snow clearing_ I dont do any field work but if plowing tilling etc was even as little as 20% of my seat time then I'd go to R1s for sure.
  2. #22
    Gold Member
    Join Date
    Jan 2012
    Posts
    316
    Moores Hill, Indiana
    MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
    Load the tires, and get the front of the logs off the ground. I skid large logs with my little B2920 with loaded R4 tires no problem.
    Are you sure it's a 40 degree slope? That is almost 100% grade, and darn dangerous to be on with a tractor.
    Actually, I'm not sure of the slope. I just guessed. It's steep enough that I would not try to go up it (again) with a two wheel drive tractor. I tried it one time with a TO-35 Ferguson pulling a 4 foot bushhog and almost didn't get back out.
  3. #23
    Gold Member
    Join Date
    Jan 2012
    Posts
    316
    That is definitely a concern. It can be alleviated by running a second safety chain from the choker to the drawbar. That way you use the 3-pt to lift the butt of the log, but the safety chain to the drawbar handles the forward pull and alleviates any "wheelie" types of loads about the axle.
    One of those contraptions is my next purchase. One of my neighbors has a welding shop and makes them. Unfortunately he's been out of comission this summer from flipping his zero turn mower.
  4. #24
    Gold Member
    Join Date
    Jan 2012
    Posts
    316
    Quote Originally Posted by Zebrafive View Post
    I'd check your owners manual or with your dealer before adding that many rear wheel weights. I have a 6415 and maximum rear weights is 3 per side.
    I will check that. I'm planning on putting 2 on the inside and 2 on the outside. I'll put 3 on on the inside if they will fit and clear the fender bracket. Mathmatically the weights would roughly be the same as loading the tires.
  5. #25
    New Member
    Join Date
    Nov 2009
    Posts
    18
    Worcester, MA
    Tire hains???
    Lots of guys use them to pull logs out of the woods.
    Brian
  6. #26
    New Member
    Join Date
    Nov 2009
    Posts
    18
    Worcester, MA
    Tire Chains???
    Brian
  7. #27
    Gold Member
    Join Date
    Jan 2012
    Posts
    316
    Bump for update. I just spent today plowing with a MF 3-14 plow and the R4 tires worked pretty good. I was able to plow down about 8 inches with limited slipping using 4x4. I used first gear in B range with the throttle at PTO RPM's. I should probably also mention the 8 107lb (856 total lbs) weights I now have on the rear wheels as well. I got two on the inside of the rim and two on the outside of the rim. The outside ones stick out about 1/2 inch past the tires. Unfortunately I can't get the 5th one on each side without it sticking out too far to snag fence posts/trees/barn doors/cars/ect. The grease zerk on the axle had to be changed to a 90 to get the weights on and still add grease. The weights made a huge difference in the tractor.
  8. #28
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,424
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    I wouldn't put 5 weights on each wheel anyway, four sounds like alot to me. I have three weights on the outside and have considered doing what you did with two per side. It would seem the tire and wheel would be better balanced and in turn less stress on the axles and bearings.
  9. #29
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,680
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    Question to the OP remains open: Did you have the butts of the logs, closest to the tractor, ELEVATED? If the butts are elevated ground friction will be considerably reduced.
    If you were plowing with the logs any kind of tire is going to spin.
    Also, if you are plowing and the log butt or a branch stub encounters an immovable object like a rock, you tractor will rear up on its back wheels in 1/2 a second. It you are going up any kind of a slope the tractor will go over backwards in 1/2 second.
    When I was new to tractors I went vertical in a John Deere 750 skidding one medium size log plow fashion on level ground, when the butt caught a ridge. It I had not been wearing the seat belt I am pretty sure the tractor would have gone over, not sure in which direction. Every pore opened and I dumped a pint of sweat.
    O N C E....B U T - N E V E R - A G A I N !
    FURTHER ON LOG SKIDDING:
    'http://www.tractorbynet.com/forums/a...k-hanging.html
    Attached Thumbnails Attached Thumbnails I think I screwed up - Tires R1 vs R4-img_0378-jpg   I think I screwed up - Tires R1 vs R4-img_0376-jpg   I think I screwed up - Tires R1 vs R4-img_0335-jpg
  10. #30
    Super Member
    Join Date
    Nov 2009
    Posts
    5,745
    Indiana
    Bobcat
    Quote Originally Posted by jeff9366 View Post
    When I was new to tractors I went vertical in a John Deere 750 skidding one medium size log, when the butt caught a ridge. It I had not been wearing the seat belt I am pretty sure the tractor would have gone over, not sure in which direction. Every pore opened and I dumped a pint of sweat.
    N E V E R A G A I N.
    did you get video?
Similar Threads
  1. I screwed up.
    By goldduster in forum Parts/Repairs
    Last Post: 06-16-2011, 04:58 PM
  2. I screwed up.
    By swampvol in forum Owning/Operating
    Last Post: 04-17-2007, 09:00 PM
  3. I Screwed Up
    By mjarrels in forum Related Topics
    Last Post: 03-28-2007, 10:23 PM
  4. I sure screwed up!
    By Boondox in forum Kubota Owning/Operating
    Last Post: 04-18-2001, 10:41 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
