Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
  1. #11
    Gold Member burnieman's Avatar
    Join Date
    Feb 2012
    Posts
    484
    Trinity County California
    John Deere 955 With 70a Loader and 7 backhoe, John Deere 110 Backhoe
    Default
    Quote Originally Posted by buickanddeere
    Just purchase the link from Deere. You have already spent more in time and driving around than just ordering the link from Deere.
    Wow. What a pompous arrogant thing to add. If you don't have anything nice to say, don't say anything . Maybe he doesn't have a pocket full of money to buy the new part. He's just asking for opinions and yours doesn't count. Why don't you buy one for him? It's the Obama thing to do and you're obviously in that camp!
  2. #12
    Super Member
    Join Date
    Apr 2004
    Posts
    6,731
    East Coast of Lake Huron
    Deere, several
    Default Re: Looking for John Deere Backhoe Part... Curved Upper Bucket Link
    Pre-heat the link in the kitchen oven to 550F and braze it together with oxy-acetylene . Then reheat to 550F and slow cool in oven.
    Shot peening the link afterwards will reduce inherent stresses.
  3. #13
    Veteran Member Carl_NH's Avatar
    Join Date
    Apr 2002
    Posts
    2,181
    Coastal NH
    01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
    Personally I would take this to a local fab/welding shop and see what they can do to fab a part - getting a quote on the phone vs a local guy that takes pride in his work - he sees it as a challenge and also opportunity - I can see maybe $150-200 range to cut and weld up a new link.
    Kubota B21TLB, Ferris IS2000, Cub Cadet 1811
  4. #14
    Join Date
    Jul 2012
    Posts
    1,126
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    Quote Originally Posted by buickanddeere View Post
    That would work pretty good-- if it was an old pump handle for decoration.
  5. #15
    Join Date
    Feb 2012
    Posts
    484
    Default
    Quote Originally Posted by arlen4720
    I concur. It will never hold
  6. #16
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    What about groove out joint, 550 in oven, weld with cast rod from TSC, after every pass, back in oven at 550 for 15 minutes, keep going until joint is filled (probably 6 passes per side), grind flush, weld 3/8 fish plate 4" past joint oneach side (8" total length), back in oven at 550 then step down 100 deg wvery 15 minutes until down to 200, then shut off oven, leave closwd to hold heat as long as possible. Pull out next day, put back on and good to go. Any pro's out there think that'll work? I've got the buzzbox and an old oven.
  7. #17
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    The part is likely cast steel, not cast iron. I wouldn't try to use cast iron rod on that.
  8. #18
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    Replace cast rod with 7018. I'll probably try it this weekend if it quits raining. Worst case scenario it won't hold. Not gonna be any more broke than it is now. lol.
  9. #19
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    Well, I decided to give it a shot. Took three passes per side, using an old propane grill to heat and cool. Here's a shot of one of the plates I welded on. The other side has one on it as well. Tomorrow I'll clean off the slag (left it on to slow cooling, etc.) and shoot some primer on it and throw it back on.
  10. #20
    Join Date
    Oct 2006
    Posts
    553
    You too. If someone's answer doesn't meet your approval it's unwanted? It's the Internet - you don't get to moderate everyone's responses. You don't like it - too bad.
Similar Threads
  1. John deere lt 155 fixer upper!
    By Bwgad96 in forum John Deere Lawn & Garden
    Last Post: 12-03-2012, 10:15 PM
  2. Backhoe John Deere 7 Backhoe bucket
    By Eucr75 in forum Attachments
    Last Post: 04-02-2012, 02:37 PM
  3. John Deere 10A Backhoe Bucket Cylinder
    By drzg2000 in forum Hydraulics
    Last Post: 04-18-2011, 07:23 PM
  4. 3-Point Hitch John Deere 4300 Broken upper 3point hitch
    By SandyTX in forum John Deere Owning/Operating
    Last Post: 12-30-2009, 07:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
