Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    Default Re: Looking for John Deere Backhoe Part... Curved Upper Bucket Link
    Chipped off the slag and shot some primer on it to slow down the rust...
    Mounted her back up (turns out the plow point peice I used as a fish plate was so thick I couldn't put the washer back on. No problem, there wasn't one on originally, I just added one to tighten it up.)...
    Headed out to dig up a big rock to see if it would hold. My wife is 5'3 for comparison and the rock is round...
    Turns out it's pretty strong. Will probably get me through until I can afford a new one. Thanks EVERYONE for all your help. Even buickanddeere who gave me the idea for using the grill for preheat. See everybody, we can all get along and share ideas peacefully. Thanks again and talk to you guys soon!
  2. #22
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    For fun, here was my jig for holding the pieces in place while I made the first welds on this side. Along with my fancy cast steel preheat oven! I ended up angle grinding both sides for a good fillet weld then welded two fish plates on. One on each side. Hopefully this helps someone who has a similar problem. Only cost me $5 in rod and $10 in propane.
  3. #23
    Join Date
    Jul 2012
    Posts
    1,126
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    Looks pretty good. Was that a 7018 you used? Did you weld it with AC?
  4. #24
    Member
    Join Date
    Nov 2008
    Posts
    45
    Stockbridge, MI
    John Deere 401C
    Yup 7018 AC. Had 1/2 pound left over from repairing cracks in the stick and holes in the nucket. I just threw them in the back of the grille to heat them up and drive out the moisture before using them.
  5. #25
    Bronze Member Dirtdeere's Avatar
    Join Date
    Oct 2012
    Posts
    67
    California Ag Valley Greenbelt
    All Ag, 4 kubotas, 6 deere, reapers, harversters, threshers, hoes, etc
    Default
    Quote Originally Posted by swines
    You too. If someone's answer doesn't meet your approval it's unwanted? It's the Internet - you don't get to moderate everyone's responses. You don't like it - too bad.
    Wow! You just did the exact same thing that you're criticizing him for.
Similar Threads
  1. John deere lt 155 fixer upper!
    By Bwgad96 in forum John Deere Lawn & Garden
    Last Post: 12-03-2012, 10:15 PM
  2. Backhoe John Deere 7 Backhoe bucket
    By Eucr75 in forum Attachments
    Last Post: 04-02-2012, 02:37 PM
  3. John Deere 10A Backhoe Bucket Cylinder
    By drzg2000 in forum Hydraulics
    Last Post: 04-18-2011, 07:23 PM
  4. 3-Point Hitch John Deere 4300 Broken upper 3point hitch
    By SandyTX in forum John Deere Owning/Operating
    Last Post: 12-30-2009, 07:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
