Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 67
  1. #11
    Platinum Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    932
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: What a brute!!!
    Quote Originally Posted by dex3361 View Post
    Do you have a tooth bar on the bucket? Looks like it is doing a great job.
    Yes. 7-tooth tooth bar on a 60" bucket. It would never cut into that hard clay like it does without teeth.
  2. #12
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    593
    Alabama PA
    Which one?
    Really wish the 855 had the same lifting power that the 955 has.
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  3. #13
    Elite Member dex3361's Avatar
    Join Date
    Aug 2008
    Posts
    3,482
    N. of Charleston WV
    Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
    Quote Originally Posted by Mechanos View Post
    Still, its doing a great job.
    Randall
    1Timothy Chapter 2:
    3 For this is good and acceptable in the sight of God our Saviour;
    4 Who will have all men to be saved, and to come unto the knowledge of the truth.
    5 For there is one God, and one mediator between God and men, the man Christ Jesus.
  4. #14
    Super Star Member RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    15,679
    Bethel, Vermont
    John Deere 4400 MFWD
    What are you using for rear ballast? Even with the toothbar, I'm a bit surprised you didn't lose traction.
    Roy Jackson
    A fear of weapons is a sign of retarded sexual and emotional maturity...
  5. #15
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    652
    WV,Preston County
    JD 1026R
    Nice looking photos ,,looks like it is doing a great job, tooth bar doing a good job.
    This spring I dug out a handicap ramp into basment of our church . Sure wish I had a toothbar ,first I would scope then turn around use BH, then scope ,then BH ... . Did this for complete ramp 4'deep x11' w and 36' long. took out 6 --6ton dump trailers of dirt ,,and at least 10 ton of rocks.. one was at least 53" wide. and 8-10 high and guessing 20 depth just barely stayed in my 54" bucket at least the old 2305 handled job and kept on working
    Keep up the good job..
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  6. #16
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,537
    Ohio
    JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
    Good job and wow, pictures just make a thread pop as though we were right there. Nice and close work up to the building as well.
    Don't sweat the small stuff...
  7. #17
    Join Date
    Aug 2010
    Posts
    932
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by techwrtr2 View Post
    Probably a good thing it doesn't. The 855's front axle and front final drives are a lot smaller and weaker than the 955's.
    Quote Originally Posted by RoyJackson View Post
    The rear's are brand new Goodyear DynaTorque II's filled with RimGuard. I also have my Frontier 2060BB hanging off the 3pt with another 160lbs. of old railroad iron bolted onto it above the cutting edge. I can put the hydraulics into relief with the loader and never come close to lifting a rear tire. I do get some wheel spin when digging in for a big bite, but those Goodyears are chewing and spitting out bars of clay. The clay has just about the perfect moisture content for maximum traction... kind of like what you'd see at a truck or tractor pull.
  8. #18
    Join Date
    Jul 2007
    Posts
    707
    WV
    John Deere 1026R
    Default
    I must say I find the trolling in this thread hilarious and I genuinely enjoyed the pictures. I also am glad to know I'm doing it right when I level myself before digging. I like to use the backhoe to start levelling sometimes because i can level myself with the outriggers and smooth it with the loader. Nice job on the excavation!
  9. #19
    Elite Member
    Join Date
    Sep 2009
    Posts
    3,185
    Murray, KY
    265 MF / JD 310B Backhoe
    Quote Originally Posted by swick1 View Post
    I like that idea to level a starting point with the BH so both front and rear axles are level so the FEL bucket cut will come out flat.
  10. #20
    Join Date
    Jul 2007
    Posts
    707
    WV
    John Deere 1026R
    Default
    I usually cut the high side and fill the low side when I do that. I got the idea from running an excavator where you do every operation with the hoe.
Similar Threads
  1. Dealer Delivered and it's a BRUTE
    By DRD in forum Kubota Buying/Pricing
    Last Post: 11-06-2010, 07:44 PM
  2. Snow CK30 a BRUTE on 16" of Snow!!
    By jordanh in forum Kioti Owning/Operating
    Last Post: 12-24-2006, 12:42 PM
  3. brush brute, anyone use on compact tractor?
    By DavidVT in forum Attachments
    Last Post: 05-04-2005, 01:28 AM
  4. Rear Blade Anyone have a "BRUTE 2" 3pt rear grader blade
    By farmacist in forum Attachments
    Last Post: 10-05-2003, 09:24 PM
  5. Towing the Brute Home
    By wasabi in forum Power Trac
    Last Post: 05-31-2002, 03:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
