Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 67
  1. #51
    Super Star Member
    Join Date
    Dec 2007
    Posts
    10,108
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Default Re: What a brute!!!
    You may say you don't know what you're doing but by taking your time and thinking it out the job has come out really nice. It looks great.
    May I be the kind of person my dogs think I am,
  2. #52
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    I envy the ground you are working on. Doesn't look to be 98% rock like I have here.
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  3. #53
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    The attached picture was going to mean something... but instead it's just a pretty picture of my tractor on a beautiful day with my man-made mountain range in the background. I spent 8 hours in seat today sloping the cut back to a mowable slope. I made 4 passes for about 20' and then I got into some good dirt... that's why I hopped off the tractor to check things out and snapped the pic. I switched up my game plan and began harvesting topsoil to place in a separate pile. Once the topsoil was harvested, I went back to sloping the cut. I got done with one end of the slope with the sun low in the sky, so I spent a little time dressing up what I'd worked for the day. I put the tractor up with just enough daylight left to take a picture of what I got done... pulled out my phone to snap a pic and the battery was dead. So, instead of a before and after... the only pic I have is before. I'll try to get a pic in the morning of the after.
    What a brute!!!-2012-11-01_12-43-30_678cr
  4. #54
    Super Star Member two_bit_score's Avatar
    Join Date
    Dec 2008
    Posts
    10,326
    Texas - from the brush and pear to the piney woods
    John Deere 110 TLB
    Enjoying the thread. Thanks for posting and letting us enjoy watching your progress!
  5. #55
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Ok... here's the before and after.
    What a brute!!!-2012-11-01_12-43-30_678cr What a brute!!!-2012-11-02_17-24-59_355sm
  6. #56
    Join Date
    Dec 2008
    Posts
    10,326
    John Deere 110 TLB
    You moved a lot of dirt. Looks like a great job.
    Will you need to do anything to prevent erosion or will grass growing back take care of that?
  7. #57
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by two_bit_score View Post
    Grass will take care of it. It's a nice gentle slope... about 5:1, or 1:5... however you want to look at it. I can comforatble operate the FEL sitting sideways on the slope, so mowing it will be a piece of cake. I'm going to dig a trench down the level pad along side the barn and bury two pipes bedded in 1/2 inch clean rock... one perforated for a subsoil drain and another tight line to pick up the downspouts off the barn. Both of those pipes will be routed out past the barn and towards the pond where they will daylight. I'm trying to capture all the run off I can and direct it to the pond to help keep it charged. Then the level pad will get graveled and will become a parking spot for my 24' trailer and other "stuff" behind that. I'll dress the slope with topsoil I harvested during the dirt moving and sow some Kentucky 31 fescue. I didn't want to mess with a retaining wall.
  8. #58
    Join Date
    Dec 2008
    Posts
    10,326
    John Deere 110 TLB
    Sounds like a good plan. Thanks for the pics an will look for any other updates you post.
  9. #59
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    Default What a bummer...
    I'm so close to finishing this project that I can see the light at the end of the tunnel. I still have some more of the slope to cut back and a little more leveling to do in front of and behind the barn, but the old girl is laying down me. Was out using it today and the blow-by smoke from the vent tube has gotten a lot heavier and just getting worse. After several hours today, the engine is now laboring to do what it was doing with ease when I started this project. I don't know if she's got enough life left in her to complete this project.
    I pulled her into the barn and pulled the injectors to run a compression test. All three cylinders were reading about 300psi. Spec for this engine is 498 +/- 14psi with a low limit of 384psi. Not good. While I was at it, ran a leak-down test. All three cylinders were passing a considerable amount of air past the rings and No. 1 cylinder was also passing air past the exhaust valve.
    I was planning on finishing this project up and then getting into the engine over the winter. Now, my plan is to mount the backhoe and open up a few places along the cut on the low side to allow water to drain out and prevent ponding. Then I'm going to take the tractor out of service and pull the head to take a look at things... re-ring and hone or bore and oversized pistons. The head will also get a valve job, guides, etc.
  10. #60
    Join Date
    Dec 2008
    Posts
    10,326
    John Deere 110 TLB
    Default Re: What a bummer...
    Hate to hear that. how many hours you got on her?
Similar Threads
  1. Dealer Delivered and it's a BRUTE
    By DRD in forum Kubota Buying/Pricing
    Last Post: 11-06-2010, 07:44 PM
  2. Snow CK30 a BRUTE on 16" of Snow!!
    By jordanh in forum Kioti Owning/Operating
    Last Post: 12-24-2006, 12:42 PM
  3. brush brute, anyone use on compact tractor?
    By DavidVT in forum Attachments
    Last Post: 05-04-2005, 01:28 AM
  4. Rear Blade Anyone have a "BRUTE 2" 3pt rear grader blade
    By farmacist in forum Attachments
    Last Post: 10-05-2003, 09:24 PM
  5. Towing the Brute Home
    By wasabi in forum Power Trac
    Last Post: 05-31-2002, 03:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
