Results 11 to 20 of 27
10-08-2012, 06:25 PM #11Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,651
- Location
- Missouri
- Tractor
- Kubota BX2200, BX2660. L5740 HSTC. M8540 HDC, some others
Re: Ditches and swales for drainage
"Most useful" is always subjective, we have both and rarely use a back blade, maybe every two or three years and could easily live with just a box scraper.
10-09-2012, 10:21 PM #12Super Member
- Join Date
- Feb 2008
- Posts
- 7,736
- Location
- somewhere usa
- Tractor
- stuff
I have a TSC 5' rear blade (think cheap and light) that I use for clearing driveways of snow. I wanted a light one so that it wouldn't mar the surface and last year used it quite a bit for that purpose and it worked out great. I tried it out for ditch work a couple of times this year and it worked to a degree if you are real patient but it is too light to do very much. I wound up bringing in the larger tractor and rearblade to cut the ditches.
I would recommend working with the boxblade and potato plow first before spending more money. For the smoothing of the pastures I would recommend a small landplane, much easier to use to get the results you want. This landplane I built for my x749 would be just right for your 1026R. This is 48" wide with 60" skids and weighs a little over 400 lbs.
10-09-2012, 11:47 PM #13Member
- Join Date
- Oct 2012
- Posts
- 46
- Location
- Northern New Jersey
- Tractor
- John Deere 1026R
Sounds like good advice. I was thinking of trying to smooth the pasture with the box blade. Parts of it were obviously plowed field, rows. Rougher than a bull on a Saturday night when mowing, not much fun even at a snail's pace. Couldn't I set the box blade at a certain height to smooth the high spots into the low spots? Then plant grass or clover?
10-10-2012, 03:27 AM #14
10-10-2012, 09:12 AM #15Super Member
- Join Date
- Feb 2008
- Posts
- 7,736
- Location
- somewhere usa
- Tractor
- stuff
You can use your boxblade too, I have a 48" Cammond boxblade but it is easier to get good results with a landplane imo. Notably easier I should say and worth the effort to build the landplane in my case. Where you are only working on your own property and not commercially you might be fine with the boxblade.
10-10-2012, 09:14 AM #16Super Member
- Join Date
- Feb 2008
- Posts
- 7,736
- Location
- somewhere usa
- Tractor
- stuff
Byron,
That trench looks pretty good but if you are going to leave it open I would wan't less taper for good grass cover.
10-10-2012, 10:29 AM #17
10-10-2012, 11:35 AM #18
If you noticed my text, I called it a trench. I buried a plastic water line in it. I only used the picture because it showed the angle of the boxblade and what you could do with it.
Dave
10-10-2012, 11:44 AM #19Super Star Member
- Join Date
- Mar 2009
- Posts
- 13,651
- Location
- Missouri
- Tractor
Pardon me for being so presumptuous. Yes, I noticed the trench, but didn't realize it was a trench to bury something then cover; only pointing out my experiences with trench/ditch/swales. Nevertheless, as I said, good job on your ditch, correction "trench".
I will consult my "Funk and Wagnels" next time.
10-10-2012, 01:01 PM #20Member
- Join Date
- Oct 2012
- Posts
- 46
- Location
- Tractor
- John Deere 1026R
Good to know! Looks like I'll have no problem making some swales to direct water. We live on the edge of a wetlands (that's what they call swamps here) and get a lot of rain and runoff. Currently, we store some of this water in basements but we're re-thinking that plan.
Similar Threads
Top N Tilt for creating drainage swales?
By tuolumne in forum John Deere Owning/OperatingReplies: 22Last Post: 04-04-2008, 08:16 PM -
Building swales
By flusher in forum Owning/OperatingReplies: 1Last Post: 12-05-2005, 08:15 AM -
lineing drainage ditches.
By LBrown59 in forum Owning/OperatingReplies: 3Last Post: 11-21-2004, 12:43 PM -
EZ spade for digging drainage ditches?
By BCF in forum AttachmentsReplies: 14Last Post: 09-25-2004, 03:43 AM -
Drainage Ditches
By Aragon in forum ProjectsReplies: 15Last Post: 09-21-2004, 08:15 PM
