Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 68
  1. #31
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: Partial overhaul on Yanmar 3TNE88
    On the surface these Yanmar engines looks kind of complicated, but they are really quite simple. Tear was very easy and quick. It only took a couple of hours to completely disassemble and strip it down to a bare block. All I have left to do is knock the freeze plugs out of the block, do some measuring and then it's off to the machine shop.
  2. #32
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Dropped off the block and the head at the machine shop. As soon as the shop lets me know what parts the head needs, I will place an order for all the engine parts needed. Once those arrive, the shop can complete the machining and get everything back to me. Hurry up and wait....
  3. #33
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Complete rebuild on Yanmar 3TNE88
    Heard from the machine shop today... all the head needs is a valve job, and of course new valve stem seals. So, I placed the order for all the rebuild parts from the Yanmar distributor: pistons, rings, piston pins and bushings, inserts, gaskets, blah, blah, blabbity blah. Continue the waiting game for the parts to arrive. The machinist wants the new pistons in hand so he can bore the block and match fit the bores to the pistons.
    I know the thread title started as a partial overhaul, but it didn't take long for this to turn into a complete rebuild.
  4. #34
    Gold Member burnieman's Avatar
    Join Date
    Feb 2012
    Posts
    484
    Trinity County California
    John Deere 955 With 70a Loader and 7 backhoe, John Deere 110 Backhoe
    Default
    Often times the simplest things can turn into the most complicated projects Mr. Mechanoise. If you can apply the fromtasion theory to your project you will move forward with ease. Also your valves in conjunction with the race bearings and journals will work better in tandem and unison if your Simmons gear is made from steel and not cast. The link that is the strongest is well inside the crank as you probably know. If you replace it, remember that you must change the gap carefully. Most of them will be on the right side of the Sinclair induction system which may or may not be applicable to your motor. Yanmar varied through the years.
  5. #35
    New Member Diesel breath's Avatar
    Join Date
    Sep 2012
    Posts
    18
    Nevada
    John Deere 955
    Default
    Well said. If you take your time and think things through you will get the job done in a more efficient way. I don't know about too much other than farm stuff but I'm pretty good at it and I have many hours at the wheel of many different tractors. I once ate 28 hot dogs at a contest. I was full and had trouble going to the bathroom the next day. It's the same thing with tractors.
  6. #36
    Join Date
    Mar 2008
    Posts
    599
    Would you be better off buying a used engine ( I know, used is what you have ) with documented hours or research if a slightly larger hp model would fit ? Your speaking lots of expensive parts for a lower powered compact. Just exploring options..
  7. #37
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    I did look around for a used engine, but they weren't exactly growing on trees around my area. The engine I am rebuilding is already a "slightly larger hp model" than the original engine. 955's came with a 3TN84 @ 33hp. What I have is a 3TNE88 @ 37hp. Keep in mind that I am getting my parts directly from a Yanmar distributor and NOT from a JD dealer. My total parts bill came in right at $1,000 and another $500 for the machine work (including the sleeves). When I have seen a used engine for sale, it has always been quite a bit more than $1,500 and it's true history is unknown... no matter what kind of "documentation" comes with it. When it's all said and done, I will end up with a renewed engine with zero hours on it for far less than I could get a used engine of uncertain history.
  8. #38
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    I need to replace the piston pin bushing in the connecting rod. My Yanmar manual lists the dimensions for an SST to remove and replace the bushings and the source for the SST is "manufactured locally". So, I went over to a buddy's house and we used his lathe to turn out the SST. I used the critical dimensions for the tool as listed in the manual, but modified it's design a bit. Here's a picture of the tool:
    Partial overhaul on Yanmar 3TNE88-2012-12-01_19-19-49_72smcr
  9. #39
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    I suppose if you are rebuilding an engine you probably will know of at least one decent machine shop.
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  10. #40
    Super Star Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    11,197
    Giddings, Texas
    JD 4310,JD5420
    Good thread. Sorry for your troubles. Sure would like to know who and what did whatever to that engine. Do you think they ran it low on coolant and overheated it and ran it hot for lengthy periods.
    One of these days....One of these days...
Similar Threads
  1. Diesel Compression Tester for Yanmar 3TNE88
    By Mechanos in forum Parts/Repairs
    Last Post: 03-04-2013, 11:43 AM
  2. BX-22: Partial Disconnection of Hydraulics
    By DOC4444 in forum Kubota Owning/Operating
    Last Post: 05-24-2011, 09:51 AM
  3. Partial or locking float?
    By RayCo in forum Kubota Owning/Operating
    Last Post: 10-25-2007, 08:14 AM
  4. Partial Maintenance
    By Adam23 in forum Kubota Owning/Operating
    Last Post: 10-05-2007, 12:13 AM
  5. full or partial syncromesh?
    By mathey in forum Kioti Owning/Operating
    Last Post: 01-22-2003, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
