Page 5 of 7 FirstFirst ... 234567 LastLast
Results 41 to 50 of 68
  1. #41
    Platinum Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: Partial overhaul on Yanmar 3TNE88
    Quote Originally Posted by Kyle_in_Tex View Post
    Good thread. Sorry for your troubles. Sure would like to know who and what did whatever to that engine. Do you think they ran it low on coolant and overheated it and ran it hot for lengthy periods.
    Looks to me like it's just plain worn out. Probably several thousand hours of use.
  2. #42
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    593
    Alabama PA
    Which one?
    It'll be a beast when you're done.
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  3. #43
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Finally got the block and head back from the machine shop today. If you look really close, you can just barely make out the line between the sleeves and the block. Now I have nice fresh round and straight bores and I can begin the re-assembly.
    Partial overhaul on Yanmar 3TNE88-2012-12-28_17-15-01_916sm.jpg Partial overhaul on Yanmar 3TNE88-2012-12-28_17-15-20_116sm.jpg
  4. #44
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Can't wait to see how this rebuilt turns out. A video of your first start-up would be cool.
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
  5. #45
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Perhaps it's still a little premature, but I'm starting to turn my thoughts to proper break-in. Having never had one of these new, I've never dealt with that. I've read a little... very little... about break-in oil, etc. Exactly what is the difference between break-in oil and regular oil? Also, some poeple say you should baby the engine for a while, and others say to use it hard. I do understand the importance of varying the RPM instead of just setting the throttle and running it at the same RPM all the time. Of course, that is a little more difficult with an HST tractor... or when running implements off the PTO. I do have some wood to split and my splitter is powered off the tractor's hydraulics which would require some extended run times at higher RPM.
    So, chime in with your experiences and advice on breaking in a rebuilt engine. Thanks
  6. #46
    Veteran Member kuboman's Avatar
    Join Date
    Dec 2009
    Posts
    1,796
    Canada
    B3200, L5740,
    Oh man you stepped in it now.
    My opinion/experience. Run it very gentle for maybe the first hour then gradually bring up the load. Varying load is more important than rpm but make sure you keep it at operating temperature. Minimal idling. One thing you need to keep in mind is that it is heat and pressure that seats the rings. If you can keep that as your aim in how you use it you will have no problem. Once you have a few hours on it don't be afraid to work it.
    L5740 LA854 loader
    L3130 LA723 loader sold
    B3200 LA504 loader
    B1550 sold
    B2620 sold
    B4200 sold
    F2680E
    GF1800
    JD 850D Gator
    JD F935 x 2 sold
    Ford 555D TLB
    Gehl 602 excavator
  7. #47
    Join Date
    Jan 2007
    Posts
    1,890
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    John deere engine engineers think break-in oil is very important because every new tractor has BI oil in the crankcase when it leaves the factory. Monitoring the operating temp is very important more than load.
  8. #48
    Join Date
    Jan 2006
    Posts
    164
    I would urge a bit of caution here - today's diesel engines are not designed with the same operational characteristics as ones of ones that are 10+ years ago. One area they are different is tighter clearances, and differing oil requirements. Older engines typically depended more on sulfur lubricants in the fuel plus zinc compounds (ZDDP) in oil, which is not in use as much any more.
    So for your startup oil, make sure you use a diesel rated oil (which will contain more ZDDP or similar compounds), and a *DIESEL RATED* break in oil is good (but not necessary) as it will typically come with more (up to 2% ZDDP).
    Also, you don't want the engine to idle for the first 30 minutes, and you want to vary the RPMS, and after that do some moderate work with it for several hours. At 50 hours, change the oil and filter. Some people will carefully cut the filter open and look for metal shavings (not a good thing) but I have never bothered, and rebuilt about 100 engines with good results.
    Good luck!
  9. #49
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Well, I finally got a chance to start re-assembling the engine today. Between bitter cold weather, fighting off the flu, and longer hours at work due to two of my guys that went out on unexpected long-term medical leave within a week of each other, and emergency situations popping up at work... I just haven't had time to do anything with it. I got the speedi-sleeves installed on the crankshaft main seal and the crank pulley. I had to chuck the crank pulley up in the lathe for some minor modification to get the sleeve to sit down on the seal surface far enough.
    With the crank ready to go, I got the block mounted back on the engine stand and the crank set in place and torqued down the main caps. Next to go on was the front plate that the gear case bolts to. This plate gets sealed onto the block with RTV and many of the bolts that clamp it down are the gear case bolts. So, I set the case in place and snugged it down to allow the sealant to cure overnight. Next to go in is the camshaft, but I can't put that in with the gear case in place, that's as far as I got on the block.
    Spent some more time cleaning some parts and prepping them for install, straightening dents in the oil pan, pressing new piston pin bushings in the rods. It felt good to finally be making progress. Tomorrow, I hope to get the lifters and camshaft installed, install the new pistons & piston pins on the rods and get the pistons/rods installed in the block.
  10. #50
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Nice! Thanks for the up-date!
Similar Threads
  1. Diesel Compression Tester for Yanmar 3TNE88
    By Mechanos in forum Parts/Repairs
    Last Post: 03-04-2013, 11:43 AM
  2. BX-22: Partial Disconnection of Hydraulics
    By DOC4444 in forum Kubota Owning/Operating
    Last Post: 05-24-2011, 09:51 AM
  3. Partial or locking float?
    By RayCo in forum Kubota Owning/Operating
    Last Post: 10-25-2007, 08:14 AM
  4. Partial Maintenance
    By Adam23 in forum Kubota Owning/Operating
    Last Post: 10-05-2007, 12:13 AM
  5. full or partial syncromesh?
    By mathey in forum Kioti Owning/Operating
    Last Post: 01-22-2003, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
