Page 6 of 7 FirstFirst ... 34567 LastLast
Results 51 to 60 of 68
  1. #51
    Platinum Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Default Re: Partial overhaul on Yanmar 3TNE88
    Progress:
    Lifters installed
    Camshaft installed
    Pistons installed on rods
    Pistons/Rods installed in block
    Oil pump installed
    Idler gear installed
    Got the oil filter adapter and oil cooler cleaned up and ready to install when I noticed that the oil filter adapter gasket that I have is not the right one. If used the gasket that I have, it would allow an internal bypass around the filter... not a good thing.
  2. #52
    Elite Member Kyle_in_Tex's Avatar
    Join Date
    Oct 2002
    Posts
    3,100
    Giddings, Texas
    JD 4310,JD5420
    No pic's? We like pics.
    You can put a gold saddle on a donkey but it's still a donkey.
  3. #53
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by Kyle_in_Tex View Post
    You're welcome to come take some.
    If you've ever assembled an engine before, you know that's it's an inherently messy process. Hands always seem to be covered in either oil or assembly lube. I'm not grabbing my camera under those conditions and if I stopped to clean my hands to snap a bunch of pics, I'd never get anything done.
  4. #54
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    583
    Northern N.B.
    2008 2305 jd
    Quote Originally Posted by Mechanos View Post
    But but but... Oh find!
    How could you be told I was french?
    4' Howse rotary cutter, mid mount lawnmower, f.e.loader, pallet forks, tiller, cultivator, middle buster, snowblower, grass-sweeper, quick hitch, trailer hitch, jodale-perry cab
  5. #55
    Join Date
    Aug 2007
    Posts
    185
    New Brunswick
    2008 JD 2320
    Maybe you could post some oil stained type abstract art........
    2008 John Deere 2320 / CX200 Loader / SB1154 Rear Blower / RB2072 72" Rear Blade
    (Sold) 08 Kubota BX25 /54" MMM / 48" LP BB/ Bro-Tek skid plates / Bro-Tek Thumb/
  6. #56
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Bolted more parts on... blah, blah, blah. Started to put the oil cooler on and noticed a slight dent on the oil filter sealing surface right inline with where the oil filter gasket rides. That would explain the annoying little oil drip I had from the oil filter area. So I took a break from assembly to address that problem. My first thought was to build up the dented area with some weld, but I was afraid that the heat may un-solder some of the joints in the cooler. I ended up filling the dent with JB Weld and letting it cure.
    Once the JB Weld had cured, I chucked the oil cooler up in the lathe to cut down the extra height of the built-up area. The dial indicator showed that the oil filter gasket surface was not true. It had a couple of waves in it... nothing much just a couple thousandths. After cutting down the extra height of the JB Weld, I took another light cut across the entire surface... just enough to true the surface. Then I polished the surface by lapping it with 220 and 400 grit paper on a hunk of marble I use for a lapping surface.
    I also needed a 1/4" NPT x 1/2" hose barb fitting and couldn't find one in town. Since I was at the lathe, I went ahead and turned one out of a 1/4" NPT brass nipple. I haven't made up my mind yet, but I may bore out a brass nut and silver-solder it onto the hose barb for wrench flats.
    When I test fit the hose on the barb, I dang near couldn't get the hose back off. I'd say it's the perfect size.
  7. #57
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Ran into an interesting glitch last night. Put the crankcase extension, oil pickup and oil pan on and flipped the engine over. After mounting the head, waterpump and valve train, I set the valve lash. When I turned the engine over by hand to adjust the last two valves, I felt something in the rotating assembly lightly hit something else and "rub" past. So, I had to flip the engine back over and pull the oil pan to investigate. Turns out that one of the rod bolts and oil pickup tube were competing to occupy the same space. I replaced the rod bolts for new ones and for some reason, the head on the new bolts are a little bit taller than the old ones.
  8. #58
    Join Date
    Oct 2002
    Posts
    3,100
    Giddings, Texas
    JD 4310,JD5420
    Click image for larger version.
    Put it in your lathe and turn down the ridge. Unless you can only stretch the bolt once. then, turn the motor back over and file on it upside down.
  9. #59
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Couldn't believe how bowed the intake manifold was. It took a good 30 minutes on the lapping table to true the surface. Anyway, the engine is ready to come off the stand and set back into the tractor. Then there are a few more tid bits to bolt back on after it's in tractor before putting the tractor back together... raditor, core support, firewall, fuel tank, hood.......
  10. #60
    Join Date
    Aug 2010
    Posts
    931
    Roosterville, MO
    JD 955/70A/7 TLB
    Default That's a wrap!!
    Today was a good day. I started out by setting the engine into the tractor and bolting it down. Installed the alternator, starter, fan and fuel filter assembly. Next was the exhaust manifold and exhaust pipe. Hooked up the flywheel to transmission driveshaft and slipped in the firewall and fuel tank. Then I set the radiator in place and secured it by installing the core support. Connected the oil lines, installed new radiator hoses and landed all the loose hoses and wires. Filled the radiator with fresh coolant, filled the engine with oil and filled the fuel tank before installing the battery.
    After priming the fuel filter, it was time to prime the injection pump and the injector lines. So, I cracked the injector lines and hit the key to crank the engine over until I got fuel to the injectors. The engine immediately popped once as soon as I hit the key... probably some residual oil in the cylinders from installing the pistons. I took this as good sign... at least I know it's building compression. Tightened down the injector lines and drew a deep breath... Moment of truth.
    I put a fresh clean sheet of cardboard on the floor under the tractor, turned the key and it immediately fired off before it turned a full revolution. It sputtered for about a second as it cleared the remaining air out of the injectors and purred smoothly. I spent the next twenty minutes varying the throttle and looking for leaks. After the twenty minutes were up, I shut it off with not a single leak found. Spent another half-hour or so fiddling with this and that and still not a drip or drop of anything showing on the sheet of cardboard. And, not even so much as a whisp or puff of smoke from the vent tube the whole time... at any RPM.
    Now to finish putting on some body panels and the hood and it'll be ready to go!
Similar Threads
  1. Diesel Compression Tester for Yanmar 3TNE88
    By Mechanos in forum Parts/Repairs
    Last Post: 03-04-2013, 11:43 AM
  2. BX-22: Partial Disconnection of Hydraulics
    By DOC4444 in forum Kubota Owning/Operating
    Last Post: 05-24-2011, 09:51 AM
  3. Partial or locking float?
    By RayCo in forum Kubota Owning/Operating
    Last Post: 10-25-2007, 08:14 AM
  4. Partial Maintenance
    By Adam23 in forum Kubota Owning/Operating
    Last Post: 10-05-2007, 12:13 AM
  5. full or partial syncromesh?
    By mathey in forum Kioti Owning/Operating
    Last Post: 01-22-2003, 10:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
