2008 John Deere 4520 Error Code 201
   / 2008 John Deere 4520 Error Code 201 #1
residualboulders
I have a 2008 JD 4520 cab tractor, with about 50 Hours on it. Just this morning when i start it up it gives me error code 201 and won't throttle up. Runs at a low idle, if I try and drive it or increase throttle it eventually kills. The nearest JD dealer is 3 hrs away. Anyone know what this error code means? I've searched the internet, can't find any info.
   / 2008 John Deere 4520 Error Code 201 #2
from what i can see in my manual its either improper signal to the fuel pressure sensor or low fuel pressure to the to the inlet of the high pressure pump .
   / 2008 John Deere 4520 Error Code 201 #3
Hiya,
First 3 things to check:
1) Take the fuel cap off and see if it runs well again: Y = fuel tank not venting, N = continue to 2
2) Disasemble and clean water seperator/fuel strainer, does it run well again? Y = Fuel strainer was clogged, N = continue to 3
3) Change primary fuel filter, does it run well again? Y = fuel filter was clogged, N= Call the dealer
Hope it helps,
Tom
Thanks Guys. I couldn't see anything in the manual about this. After talking to a repair guy and experienced neighbor farmer, sounds like Tom is probably right. I'll clean or replace the filter and see if that fixes the problem.
   / 2008 John Deere 4520 Error Code 201 #5
What fixed your problem, having same issue
1974 Honda CB360T Motorcycle (A54865)
1974 Honda CB360T...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
Diesel Generator (A55851)
Diesel Generator...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
1998 FREIGHTLINER CST120 TANDEM AXLE SLEEPER TRUCK (A56129)
1998 FREIGHTLINER...
