Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. #21
    Gold Member smalltown's Avatar
    Join Date
    Jan 2011
    Posts
    421
    Western Maine
    2011, JD 2520
    Default Re: Post your land projects! New 2520 owner here
    Chris not imbarassed at all. I am glad we could point that out to Mark so he can get those hoses out of harms way!
    62D MMM, 200CX loader, iMatch Quick Hitch, Ballast Box, #46 Backhoe
  2. #22
    Join Date
    Mar 2008
    Posts
    599
    Now that we have the hoses securly tucked away... are there any other landscape / woodland improvement projects underway ?
    I had to resort to using the NH TC55 and Bradco 611 backhoe to build trails and remove stumps. This is why the next project is a stump grinder.
  3. #23
    Advertiser
    Join Date
    Mar 2009
    Posts
    393
    MA
    Various
    Here's a little stone wall started yesterday. The first thing I had to do was excavate down to some old drain pipe work, rearrange the configuration, and avoid the underground power. Not a day to have a beer in the cup holder.
    The 2520 was indispensable. I used the landscaping fork tines to harvest the large stones. The big center stone couldn't quite be lifted (almost though) so it was dozed and rolled through the mud. Rolling large stones is easy with the little forks - just be sure to keep everyone out of the way in case it gets away and starts to roll. They're also handy for dropping them onto another rock to split them, if you can catch the grain just right.
    I can't wait for this wall to be finished. It will be a big help catching heavy rains and eliminating erosion and a bad ice problem in the winter, and will also work as a loading dock hidden in full sight (shhh, that's a secret!).
    Attached Thumbnails Attached Thumbnails Post your land projects!  New 2520 owner here-2012-11-10_10-56-51_962-a   Post your land projects!  New 2520 owner here-2012-11-11_10-26-59_913-a
  4. #24
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Quote Originally Posted by Artillian View Post
    Chris,
    If you haven't backfilled it yet, you might condsider cutting that Tee out a rotating it 90 degrees and extending a pipe to grade and installing a clean out. Just a thought.
  5. #25
    Join Date
    Jan 2011
    Posts
    421
    Western Maine
    2011, JD 2520
    Chris how is that thumb on handeling the rocks? I lick my chops evey time I see that
  6. #26
    Advertiser
    Join Date
    Mar 2009
    Posts
    393
    MA
    Various
    Mechanos,
    Thanks, but if that pipe gets clogged up in that spot, there will be much bigger problems. The drain drops about 6 feet underground after that last turn. It was installed 30 years ago before I got it.
    To keep the intake clean, the perforated sections are surrounded by landscaping material. Another section I installed 3 years ago this way is working great. It's kind of a frankenstein system, but it's the best I could come up with with all of the factors at hand.
    LOVE that 990 by the way!!!
  7. #27
    Join Date
    Aug 2010
    Posts
    1,106
    Roosterville, MO
    JD 955/70A/7 TLB
    Mechanos,
    ...LOVE that 990 by the way!!!
    Thanks... I assume you are referring to my 955. It's been quite a trooper on my dirt project... right up until the engine laid down on me. I'm getting some things lined out in my barn so I and start the tear down/rebuild of the little Yanmar diesel.
  8. #28
    Join Date
    Mar 2008
    Posts
    599
    Default Re: to buy Viagra at UK pharmacies, because
    I am impressed with the work the 2520 is completing with a backhoe. When I look at them in the sales lot, the size of the cylinders, hoses and brackets it is a larger work horse then I imagined.
  9. #29
    Advertiser
    Join Date
    Mar 2009
    Posts
    393
    MA
    Various
    Smalltown, I originally wanted the thumb for building stone walls. To be honest, my landscaping forks get much the same tasks done and with more flexibility than the thumb. These little backhoes are not very precise and it's usually more work than it's worth trying to set a stone. I adapted the thumb to the 46, but never really do much with it. Once in a while I use it for plucking something, but I'm just so much more used to thinking with my forks at this point. It's probably just my own preference.
    Mechanos, sorry. I misspoke. Goin too fast.. Of course, 955. Sorry to hear about your engine. I read your thread about reviving it [the tractor], but just a quick visit here and there. Your into it too far to turn back now!
  10. #30
    Veteran Member Runner's Avatar
    Join Date
    May 2007
    Posts
    1,682
    Missouri
    John Deere 2520, 1989 John Deere 185, 1960 Panzer T70B
    Smalltown,
    I hate to be a party pooper, but I think your hose hanger may be installed incorrectly. But hey, if you like it that way then there's nothing wrong with that. Plus, the mounting location that the installer found looks to be intuitive, if I were the sort of person to assemble things without reading first.
    Here is a scan of the Deere installation instructions for installing this hose hanger. These particular instructions are for the Front quick hitch, but the hose hanger installation is the same regardless and this is how the hanger is configured on my 2520. I'll try to get a picture, but it's probably going to slip my mind a few dozen times first.
    For the record, Smalltown's hose bracket is installed correctly for an old-style rig. Mine is a 2007 and is installed exactly the same way, i.e., bolted through a tab under the floorboard. I think this was a better way to do it and can't figure out why they changed it on the newer 2520's. Perhaps the newer models don't have the dedicated mounting tab?Post your land projects!  New 2520 owner here-our-2520-002-b-jpg
    Runner
Similar Threads
  1. New Land Owner
    By MountainHorse in forum New Member Introductions
    Last Post: 11-12-2012, 02:58 PM
  2. new land owner says hi
    By BluManChu in forum New Member Introductions
    Last Post: 09-09-2011, 09:33 PM
  3. New land owner
    By TheOnlyQP in forum New Member Introductions
    Last Post: 07-14-2011, 08:41 PM
  4. First Post - Many Projects (long post)
    By Kyle241 in forum Projects
    Last Post: 09-16-2010, 09:40 AM
  5. New land owner
    By house in the woods in forum New Member Introductions
    Last Post: 08-09-2010, 09:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
