Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    10
    Northwest, MO
    JD 4600
    Default JD 4600 HST sluggish when changing directions
    I have a 2000 4600 HST that is sluggish when changing directions from forward to reverse and visversa. I have had the tractor about 4 months and up until the last week or two it has worked fine. It does't seem to be as bad when it is cold. I took it to the dealer a week ago and they changed the fluid and filter and said they couldn't get it to act up. I drove it back to my shop about a quarter mile away, put a blade on it started blading and it seemed to be working normal. About 5 to 10 minutes later and several times of changing directions it started acting up again. When it happens and you chang directions, there is a lag of about 3 to 4 seconds before the tractor starts moving in the opposite direction. Any Ideas? Please
    Chuck
  2. #2
    Silver Member wthompson's Avatar
    Join Date
    Jan 2012
    Posts
    170
    Southeast, GA
    John Deere 4600HST L100 L120
    Default Re: JD 4600 HST sluggish when changing directions
    l haven't had any trouble with the HST drive on mine, but i would like to know what you figure out. Have you checked the linkage? Sorry i can't help. Anyone else have a suggestion?
  3. #3
    Join Date
    May 2008
    Posts
    1,304
    Eastern Ia
    JD 4310 eHydro,
    On the 4x10 series there is return springs that push the pedal back up. I wonder if the 4x00 series is the same. Could the linkage need a shot of lube?? I am fairly sure that it would not let you go in 2 directions at once.
  4. #4
    New Member
    Join Date
    Nov 2012
    Posts
    10
    Northwest, MO
    JD 4600
    I have checked the linkage and it appears to be ok. The pedals move fine. It acts more like it a hydro problem. There is an electro-magnet along side the foward pedal that seems to have a nut broken off of it, letting it rub against the side of the pedal arm. I'm not sure what its function is.
  5. #5
    Join Date
    Jan 2012
    Posts
    170
    Southeast, GA
    That electromagnet is the cruise control. There is a micro switch under there as well but i think thats for neutral start. Wish i could be more help.
  6. #6
    Join Date
    Jan 2012
    Posts
    170
    Southeast, GA
    this is a diagram of what hst pedals should like. With tractor engine off, move each pedal and watch the movements of linkages to hydro.
    JD 4600 HST sluggish when changing directions-mp28035________un25apr02-gif
  7. #7
    Epic Contributor RoyJackson's Avatar
    Join Date
    Nov 2001
    Posts
    22,276
    Bethel, Vermont
    John Deere 4520 MFWD, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
    Aren't there poteniometers below the HST pedals?
    Seems like I've read threads about this...they were concerning the 4300 or 4400, IIRC.
    Roy Jackson
    "There ain't no such thing as a free lunch..."
  8. #8
    New Member
    Join Date
    Nov 2012
    Posts
    10
    Northwest, MO
    JD 4600
    Quote Originally Posted by RoyJackson View Post
    This model doesn't have the poteniometers.
  9. #9
    New Member
    Join Date
    Nov 2012
    Posts
    10
    Northwest, MO
    JD 4600
    Quote Originally Posted by wthompson View Post
    That makes sense. I should have thought of that myself.
  10. #10
    New Member
    Join Date
    Nov 2012
    Posts
    10
    Northwest, MO
    JD 4600
    I did forget to mention that when the tractor does start moving that it will get up to speed where ever you have the pedal set. It just takes it a while to get there. And once you get up to speed and you start up a hill or put a load on, it doesn't seem to slip. When you let off the forward pedal sometimes it doesn't seem to slow down as fast as does when its working right.
Similar Threads
  1. JD 4600 hst sluggish when changing directions
    By ChuckB72 in forum John Deere Ag Tractors
    Last Post: 11-08-2012, 01:19 PM
  2. JD 4600 HST
    By Tommy Griffis in forum Hydraulics
    Last Post: 04-07-2011, 03:10 PM
  3. SLUGGISH HST
    By flINTLOCK in forum Owning/Operating
    Last Post: 06-12-2007, 03:59 PM
  4. Sluggish BX22 HST Pedal
    By RiverV in forum Kubota Owning/Operating
    Last Post: 09-25-2003, 12:59 PM
  5. 4600 HST
    By fishnhunt365 in forum John Deere Buying/Pricing
    Last Post: 08-27-2002, 06:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
