Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    1
    georgetown, tx
    john deere 5103
    Default I HAVE A JOHN DEERE 5103 TRACTOR WITH BRAKE ISSUES
    THIS TRACTOR HAS HYDRAULIC BRAKES THAT SEEM TO WANT TO DRAG ALL THE TIME. I HAVE CHANGED THE HYD FILTER AND FLUID AND EVEN BLED THE BRAKES. FOR SOME REASON THE BRAKES AREN'T RELEASING TOTALLY IN THE FINAL DRIVE ASSEMBLIES. THIS TRACTOR IS LIKE NEW AND ONLY HAS 260 HRS ON IT. DOES ANY ONE HAVE ANY SUGGESTIONS OR HAS HEARD OF THIS KIND OF PROBLEM THAT CAN POSSIBLY HELP? I DON'Y WANT TO PULL THE FINAL DRIVES IF I DON'T HAVE TO.
  2. #2
    New Member
    Join Date
    Jun 2009
    Posts
    23
    Dallas TX
    1968 FORD 4500 FELB 1968 Massey 1100, 1959 Massey 35, 2000 Kubota B7500HST, 1987 Kumatsu D20-PL6A, 1974 Sears Garden tractor, 1982 Gravely 5260 , 1965 Gravely Model L DOE
    Default Re: I HAVE A JOHN DEERE 5103 TRACTOR WITH BRAKE ISSUES
    TractorData says that the 5103 machine has differential wet disk brakes. Does that mean the fiction surfaces are in the differential?
    Is there a casting facing the rear of the machine which can be taken loose? I would also make sure all your control rods are not sticking anywhere because it is amazing what a little rust will do in the wrong place.
    Good luck
  3. #3
    Join Date
    Dec 2001
    Posts
    1,336
    Maryland
    I HAVE A JOHN DEERE 5103 TRACTOR WITH BRAKE ISSUES-lvp942_________un29may97-gifFirst, you need to be sure the brake pedals or the brake valve is not sticking and not allowing brakes to release. If that seems ok, then jack up the tractor and see if the wheel spins free. If it is dragging, loosen the bleed screw and see if it frees up. If it still drags with the bleed screw loose, then the problem is in the brakes. The final drives will need to come off. You might have defective retractor pins. They are #1 in the diagram. When reassembling the brake into the final drive, the retractor pins need to be pressed in until they bottom out.
  4. #4
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,053
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    I'll bet it's parts key #1. My neighbor had to R&R final drive housings on his 5310 for the same thing.
Similar Threads
  1. John Deere 400 late 70's early 80's lawn tractor brake shoes
    By Steveamy40342 in forum John Deere Lawn & Garden
    Last Post: 06-27-2012, 05:22 PM
  2. John Deere 5510N tractor brake problems
    By RogerMartin in forum John Deere Ag Tractors
    Last Post: 04-12-2012, 09:27 AM
  3. john deere 5103???
    By chrisdvorak in forum John Deere Buying/Pricing
    Last Post: 10-17-2009, 09:56 PM
  4. Price Check Used John Deere 5103 Pricing
    By Kingnutin in forum John Deere Buying/Pricing
    Last Post: 04-04-2008, 09:22 AM
  5. john deere model 5103 good tractor?
    By h2onut in forum John Deere Buying/Pricing
    Last Post: 04-20-2004, 12:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
