Page 2 of 7 FirstFirst 12345 ... LastLast
Results 11 to 20 of 66
  1. #11
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    655
    WV,Preston County
    JD 1026R
    Default Re: JD2210 upper driveshaft service/grease
    I always greased my 2305 from underneath. Other members said the cup or what ever correct name on end of grease gun needed tapered to fit on grease fitting. After using the electric grinder several times and little by little was always able to use the tip of the grease gun. Had the needle point just didn't seem to work for me so when I found that info tried and always had good luck.
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  2. #12
    Platinum Member Henri88's Avatar
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    I have to say that I have a pit in my garage which make it so much easier to get at it.
    Henri
    How could you be told I was french?
    Rotary cutter 4' Howse , mid mount mower 54'' , f.e. loader 200CX , tiller RT1150 Frontier , cultivator PC1001 Frontier , middle buster PM1001 Frontier , JD 47'' front snowblower , pallet forks , 4' boxblade Agriease , grass-sweeper , quick hitch Speeco , trailer hitch , cab Jodale-Perry , trailer 16' galvanized Easy-Hauler ,
  3. #13
    Member
    Join Date
    Oct 2010
    Posts
    43
    NW Maine
    JD 2305
    I've done my 2305 three times from underneath with a needle adaptor. It's a total PITA! First I have to jack the tractor high enough to fit underneath on the creeper, move the hydraulic hoses out of the way, put on a headlamp and then I use an air powered grease gun. Takes about 45 minutes to do two lousy fittings. I'll be checking out the access panel idea when spring returns.
  4. #14
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,302
    Missouri
    Kubota M9540, Ford 3910FWD, JD2210
    I've not looked at the 2305 but have heard they are built different and are normally greased from below. On the 2210 the frame is built differently and you can't see the front joint at all from the bottom. Not sure if you can cut the access hole in the floorboard to gain access to the rear joint on the 2305.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  5. #15
    Join Date
    Oct 2011
    Posts
    109
    John Deere 2305 (2010)
    Default
    Okay gents, have to admit stupidly here. I took my mower deck off, climbed underneath to grease the two drive joints. Both are easy to see but impossible to get a gun on the zerks. Seen someone posted about a needle.... I have one from who knows where. Someone please tell me how to use it. Thanks, Bill. 2010 - jd2305
  6. #16
    Join Date
    Oct 2011
    Posts
    109
    Default
    Quote Originally Posted by Wvanatti View Post
    Attachment 292953
  7. #17
    Join Date
    Oct 2011
    Posts
    109
    Default
    JD2210 upper driveshaft service/grease-image-2913883661-jpg
  8. #18
    Join Date
    Nov 2009
    Posts
    759
    Northern N.B.
    2008 JD 2305, 800hr
    Yes, that is pretty much what I use. Snap your grease gun on the zerk of the needle first and push your needle on the tip of the joint zerk where the grease goes in. Push hard enough to hold the needle in place and give it a few pump. I have put a picture if you look on post 9. Sorry if the pic is somewhat blurry.
    Henri
  9. #19
    Join Date
    Oct 2011
    Posts
    109
    Default
    Perfect explanation. I just put the mower back on to mow but ill do it next week before I mow again. Orlando incase your wondering :-)
  10. #20
    Super Star Member
    Join Date
    Dec 2003
    Posts
    11,622
    NC
    Kubota Grand L3830
    I would recommend stopping in at an auto suppy house, O'Rileys, Auto-Zone, etc and purchase one of the newer "Needles". The new ones have a slip collar that slides down and locks somewhat the needle injector to the grease gun fitting. The one shown by you will require three hands with a air powered greased gun and four or more hands with a manual grease gun.
    Sticker shock may get you. I think I paid somewhere in the neighborhood of twenty bucks for the last one I purchased. But then you know what they say about old people and memory.
Similar Threads
  1. Upper Valley Tractor
    By mizzentop in forum Kioti Owning/Operating
    Last Post: 10-12-2012, 09:10 AM
  2. Replies: 15
    Last Post: 04-13-2011, 03:11 PM
  3. JD 2240 - Fixer' Upper'
    By Boots in forum Photos
    Last Post: 03-29-2001, 09:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
