Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    New Member DeereGirl's Avatar
    Join Date
    Dec 2011
    Posts
    14
    Belleville, MI
    John Deere 1023e
    Default Using a 3 point Log Splitter on my John Deere 1023E
    I need some opinions from you guys. I'm new to the thought of using a log splitter of this type. I'm used to a standalone gas splitter. However, I have a barter opprotunity that sounds pretty good.
    I have the opprotunity to pick up a Speeco 3 point Log Splitter. Here's the description that I've been given and pictures look really good:
    "I bought this on CL a few months ago for $450 and only have split a half dozen logs. I believe I am the 3rd owner, but none of us has used it very much. The splitter is designed to operate using the hydraulic system of a class 1 or 2 tractor with a 3 point hitch system. Also, you could connect it to a stand alone hydraulic pump. It works perfectly. There is some deterioration on the covering of the 8 foot hoses but they do not leak. I installed a brand new "open" type hydraulic control valve ($140) and new quick release connectors ($40). It includes legs, but I have not used them. They seem to be selling new for about $850 (which may or may not include shipping). New they usually do not include hoses and connectors (+/- $100). "
    My questions are as follows:
    1. Are spitters of these types worth the money?
    2. I understand that they work of the hydrolics of the tractor, will there be any reason why mine will not be able to handle it?
    3. I'm sure there should be more questions asked but I'm not familure enough to know which ones. Is there something else that I should be thinking of?
    Here's a PIC:
    Using a 3 point Log Splitter on my John Deere 1023E-3e53m43n35l25o25hbcbh2291ead1b4d11c8c-jpg
    Any help would be great. If this is a good offer, I would like to jump on it.
  2. #2
    Super Member greg_g's Avatar
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    JD3720 Cab, 300X loader with 4-in-1 bucket
    Default Re: Using a 3 point Log Splitter on my John Deere 1023E
    Your 1023 hydraulics may not result in splitter performance consistent with your expectations. Pg12 on the manual for this splitter has pressure versus flow rate versus cycle time charts. If you don't have a copy, you can download one here. Then look up the hydraulic pressure and flow numbers in your 1023 manual. Comparing the splitter charts with the tractor data will give you splitting tonnage and cycle time.
    //greg//
    USN (Ret)
    Former Chinese tractor owner (x4)
    Current John Deere owner
  3. #3
    Gold Member Wyobuckaroo's Avatar
    Join Date
    Nov 2010
    Posts
    389
    Frozen bush of NW BC CA
    John Deere 2032
    If I had a chance at a splitter like that at a good price, I would scoop it up in a minute.
    My tractor rate of flow is about 5gpm so too slow for a direct hook up.
    If I'm going to have to run the motor at PTO rpm I have thought of running a PTO driven pump with an oil tank.
    Also I would convert it to a rear facing vertical only splitter on the 3pt hitch so I could add a trailer hitch for a two wheel trailer.
    Good luck
  4. #4
    Join Date
    Dec 2011
    Posts
    14
    Belleville, MI
    John Deere 1023e
    Ok Guys.... Here's what the specs are on the JD 1023e... thoughts?Using a 3 point Log Splitter on my John Deere 1023E-untitled-picture-png
  5. #5
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    If the cyl is a 4 in cyl, and 2 in shaft. and tractor hyd pressure of 2000 psi, the splitter would be rated at about 12 ton. That will do most jobs.
    Since the flow to the valve is low, Prince makes a LSR-3060 log splitter valve which will speed up the splitting time.
    http://www.princehyd.com/Portals/0/p...R3060Flyer.pdf
    Your tractor should be able to use this PTO pump below, and provide faster speeds and more power.
    This pump can supply about 7 GPM at 2250 psi.
    Surplus Center - 3.6 CU IN PRINCE HC-PTO-7A PTO PUMP 540 RPM
    You should check your log splitter valve relief setting, and make it equal to the tractor relief setting.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  6. #6
    Join Date
    Feb 2005
    Posts
    986
    Central WI
    Looks like it must mount sideways on the 3 pt. I'd rather have it fore/aft. and push the logs off the rear. This way I can drive forward to clear the wood. I also prefer a 4 way wedge for 90% of my splittting. It's 3x as fast this way. To me it looks like you have one choice as to which side to stand on plus the wood falls at your feet/in the loading area.
    I posted a pic recently in another thread of teh Wallenstein unit that I use.
    Agreed on the pump/reservoir given the low hydraulic flow of your tractor.
    JD3720 300CX FEL, 48" forks, MX-5, RB1172, BB1172 air seat susp
    JD 455 2 wheel steer
    JD x750-Auto Connect w/60" HC deck
  7. #7
    Elite Member
    Join Date
    Apr 2011
    Posts
    3,036
    Boston
    L3700SU
    I have a splitter that I used on my BX22. I believe it is a 18 ton....? My BX had a flow rate in the 6gpm range. All that said, it worked fine for me. Cycle time was in the 13-16 second area and had plenty of power to split anything I could fit into the opening, other than big knots. It is no speed demon and would not be efficient for commercial work, but I could be shoulders deep in split logs in about a hour and barely break a sweat.
  8. #8
    Join Date
    Dec 2003
    Posts
    6,086
    Western Kentucky
    Quote Originally Posted by Wyobuckaroo View Post
    It shouldn't be necessary to run at PTO rpm when the splitter is powered by tractor hydraulics. You only need sufficient engine revs to spin the pump up to its max gpm rate. I haven't used my 3730 for splitting yet. But behind my previous tractor, 1100 rpm is all it took to run the SpeeCo at its rated capacity.
    //greg//
    USN (Ret)
  9. #9
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    greg_g,
    What was the rated GPM capacity on your splitter.
    The cheapest log splitter valve will handle about 25 GPM.
    I am confused by your 1100 engine rpm statement, with 2600 engine rpm available .
    If you run it at 1100 rpm, you would only pump about 3 GPM, although that might be enough.
    J.J.
    Git er done.
  10. #10
    Join Date
    Dec 2011
    Posts
    14
    Belleville, MI
    John Deere 1023e
    Default
    Thanks to all... I have not hear back from the person who offered yet. The splitter was on Craigslist for $400 and my snow blower is on there for $600. I was probably willing to go down to $500 but still not sure. Like I said, the person that made the offer has yet to contact me back. I'm still wondering if I should hold out to see if I get a cash offer. Then I can either put it towards a splitter or some other attachments for the tractor. My most recent purchase was a box scraper. I love it!
Similar Threads
  1. John Deere 135 PTO Drive Screw Log Splitter
    By John Dear in forum John Deere Buying/Pricing
    Last Post: 10-04-2012, 06:17 PM
  2. Buying Advice John Deere 1023E
    By RascoM in forum Buying/Pricing/Comparisons
    Last Post: 09-30-2012, 08:24 PM
  3. Log splitter valve for a 3 point splitter
    By Rio_Grande in forum Build-It Yourself
    Last Post: 10-28-2011, 01:39 PM
  4. John Deere 4 log splitter questions
    By namder in forum Hydraulics
    Last Post: 08-01-2011, 01:12 PM
  5. How to add log splitter to John Deere 870????
    By JS415 in forum John Deere Owning/Operating
    Last Post: 12-14-2005, 10:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
