Results 1 to 6 of 6
  1. #1
    Platinum Member chevy's Avatar
    Join Date
    Mar 2003
    Posts
    627
    East Central, Indiana
    John Deere 4120 John Deere 1026R
    Default 2720 & 47 Snow Blower
    We got over 9" of wet heavy snow yesterday, so I finally got a chance to use my 2720 & 47 snow blower. I got the 2720 in January, I have had the 47 snow blower for several years.
    I had it all setup for last winter, but we did not get any snow. After hearing the forecasts of all of the snow that was coming yesterday, I got the cab & the snow blower installed. Sometime after last winter was over I got a remote chute adjusting cable for the snow blower. I had forgotten about getting it until I got the snow blower out of storage. So I also got that installed, although I had to reroute the cable after I saw it was getting between the front hitch & stop.
    Because the 2720 has a lot more power than the 2320 I traded in, I stocked up on shear bolts. After seeing the type of snow we had, I was sure I would need several because I always broke at least one every time I used it with the other tractors I had used it on. To my surprise, I did not break one.
    The chute adjuster worked great. I did several of my neighbors drives. If I had not had the chute adjuster, I would not been able to have done some of them because of cars, near by houses & decorations.
    The 47 snow blower worked better on the 2720 than it did on the other tractors I have used it on. Those tractors were the 455, 2210, 2320.
    After using the snow blower, There was a lot of slush on the driveway, so I went back over the driveway again with my 1026R & blade with a rubber edge.
    This was how I routed the cable the first time. As you can see in the photo, when the chute was rotated to the left, the cable would get in between the hitch & upstop.
    This is how it is now.
    Having the cab on the tractor, with a window where the cable is normally mounted & not getting any mounting hardware with the cable, made mounting the handle a challenge. I made the mount easy to install & remove, in case I need to use the loader also.
    I like this location much better than the normal mounting location. It is very easy to reach & adjust.
    John Deere 2025R, H130 Loader, 62D Mower Deck, John Deere 655 Tiller, Front Grader Blade, Frontier LR2072 Landscape Rake, Frontier Pallet Forks, Woods GB60 Box Blade
    John Deere X739 AWS 4x4 with 60HC deck.
    John Deere 825i Gator
    John Deere Tractors I have owned in the past.
    425 AWS, 455, 4400, 2210, 4710, 2320, 2720, X475, 1026R, 4120
  2. #2
    Elite Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    2,638
    Upstate NY
    JD X585
    Default Re: 2720 & 47 Snow Blower
    Awesome setup! Isn't it amazing at how fun it is to move snow with a cab!
    people can say anything they want about buckets, but give me a front snowblower
    with a cab any day for snow! well, at least for the kind of snow we get around
    here, averaging 200 inches a year i'd guess.
    JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F620 with 60". JD HPX gator. JD T23 trimmer
    JD CS56 and CS36 saws. JS35 WB mower.
  3. #3
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,960
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Nice Rig
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  4. #4
    Platinum Member etcallhome's Avatar
    Join Date
    Mar 2005
    Posts
    655
    WV,Preston County
    JD 1026R
    You do have a nice setup ,younger brother has a 2720 he really like the extra height and hyd for using forks at his sawmill.
    Agree about having the blower over a front bucket ,cab and heater..Big difference. Yesterday had about 1 1/2-- 2 1/2 " of sleet, ice balls , freezing rain so I used the blade to try and get down to the concrete or whatever the surface. Same for this morning for about 2 hrs , took blade off and did the rest of the day with blower,,so much nicer !!! Been able to run tractor at 2100--3200 ,most of the time 26-2800rpm seems to do get.
    I will say whether I'm mowing or using snow blower , If I get into some deep snow or tall grass ,seems like the engine takes longer to catch up to the rpm I had been running just a sec before. Don't remember the other diesels I had doing this. They seemed to catch up quicker than the 1026r . Either way the 1026r does a good job.
    Have fun and be safe !!!
    JD1026R H120 fel w/54"bucket; 60" mmm ; 260 BH/w 12" bucket; ballast box; rear weights; front quick hitch w/angling kit and 54 " blade ;3pt rear 60" blade ; JD 47" frt snowblower ; Original Tractor Cab;Bush Hog 47" tiller and 15" Middle Buster
  5. #5
    Join Date
    Mar 2003
    Posts
    627
    Thanks everyone.
    In my opinion, having a cab is a must with a snow blower. I used it only one time without a cab.
    I looked like a snowman when I was done & also frozen. I had an original cab on the tractor before the next snow. I do not have heat in the cab, but I stay warm.
    I was blowing snow for over 5 hours the last 2 days & stayed warn the whole time. I plowed snow on the 1026R for about 35 minutes without a cab & I was freezing by the time I got finished.
    I have an Original cab that I had on a 2210 that I am going to see if I can make it work on the 1026R.
  6. #6
    Gold Member
    Join Date
    Nov 2008
    Posts
    403
    Maine
    '09 JD 5105M Cab & '05 JD 4720 Cab
    Quote Originally Posted by chevy View Post
    Apart from ingesting solid objects the major cause of serial shear bolt smashing is the auger grazing the ground. If you broke pins almost every time you used the blower with the other tractors perhaps it's because it wasn't a good fit. Sometimes when we adjust a blower's "angle of attack" so to speak, we don't realize that it slightly tilts forward once the tractor is in motion. Sometimes this causes the auger to graze the ground causing enough enough stress to snap shear pins but not enough to be felt by the operator.
    JD 5105M & JD 4720 Cabbies w. Shoule reversible snow blade/Shoule rear snowblower; Pronovost blower; backhoe and some attachments I have no idea what they are for.
Similar Threads
  1. Front End Snow Blower for 2720..how much$$
    By brian22 in forum John Deere Owning/Operating
    Last Post: 11-19-2011, 10:33 AM
  2. snow blower pump & motor
    By wrench monkey in forum Hydraulics
    Last Post: 02-09-2011, 01:09 PM
  3. Snow NEW SNOW BLOWER & SNOW STORM
    By RADIUM in forum New Holland Owning/Operating
    Last Post: 05-29-2009, 08:11 AM
  4. JD 3320 w/cab & Snow Blower
    By DrainPondDesign in forum John Deere Owning/Operating
    Last Post: 05-22-2006, 12:33 PM
  5. Snow B-7800 & B-2910 snow blower
    By kenta in forum Kubota Owning/Operating
    Last Post: 12-22-2004, 09:59 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
