Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1
    Join Date
    May 2009
    Posts
    628
    South Mississippi
    2008 John Deere 5303 MFWD
    Default JD 5303 Front Drive Shaft Guard
    A couple weeks ago I got in a bind working near the edge of a small creek. Front tires got over a buried log and I couldn't back out or push with loader and back out. Front was bottomed out. Wound up with second tractor and PTO winch to pull it out. Got it home and cleaned up and didn't see any damage. I had just installed my horizontal exhaust the day before and amazingly it was not damaged either.
    I noticed a noise this afternoon while running at road speed going to swap implements. Sounded like a stick flopping. Upon further inspection attached is what I found. I am certain this occurred with the creek incident and the guard was what I was hearing. It looks like the attachment points were stripped out. I managed to work it back into place, but after 30 to 45 minutes of grading drive I noticed it had come off.
    Questions:
    1) Is it possible to replace this piece (s) without removing the drive shaft?
    2) Any likelihood anything else damaged? Doesn't seem to be.
    3) Looks like I might have room to run a short screw through to hold together, but I don't want to start "patching" either.
    The pictures show how it was found, it slid back on and it slipping back off.
    Any suggestions?
  2. #2
    Veteran Member DT86's Avatar
    Join Date
    Dec 2010
    Posts
    1,665
    SW VA
    David Brown 885, Kubota RTV 900, Kubota 9540
    Default
    It looks as though you might be able to turn the cover a quarter of a turn and drill a new hole to reattach it to the end.
    You won't be able to replace without removing one end of the drive shaft.
    As for other damage the front shaft could be bent if you hit that log pretty good. But I doubt it.
    Treat me good and I'll treat you better, treat me bad and I'll treat you worse.
  3. #3
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    Didn't intend to have a Deere fleet - it just happened
    Default Re: JD 5303 Front Drive Shaft Guard
    I suggest working the guard back onto the collar. Then place a hose clamp over the guard, clamping it to the collar.
    Be very careful of placing any fastener, that you don't contact the rotating shaft. Not for fear of damage, the noise will drive you crazy.
  4. #4
    Platinum Member Rustyiron's Avatar
    Join Date
    Mar 2011
    Posts
    780
    Lakes Region, Maine
    M 9540 Kubota
    That is plastic right? How about a little construction glue? Screw, hose clamp, all good ideas.
    We need more people to WORK for a living and less people to VOTE for a living!
    (proven on 11/6/12)
  5. #5
    Join Date
    May 2009
    Posts
    628
    South Mississippi
    Default
    Yes it is plastic. I do not think it bent anything and don't feel any sort of vibration. Looks like it was held together with a plastic rivet or something. My guess is while I was backing up it contacted the log while turning. Hate to "rig" it but don't see the need to carry it to the extreme. The only reason/benefit of using screw is it could be easily removed. Hose clamp plus short self tapping sheet metal screw may be enough to hold it. Was a little surprised it backed off today just grading the driveway.
  6. #6
    Gold Member
    Join Date
    Oct 2008
    Posts
    484
    Greensboro, NC
    The guard is made of poly -something. Not glue friendly. Although, a hot melt glue might work.
  7. #7
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,114
    Front Range of Colorado
    JD 4200 C.U.T. & JD 130L Lawn tractor
    Quote Originally Posted by DT86 View Post
    That would be my first choice.
    I assume by the looks of it that this guard is meant to keep crud off the machined surface of the driveshaft, and isn't some blasted lawyer mandated item to prevent decapitation of prairie dogs. If it's there to keep crud off, then I would find a way to fix it. If it's a lawyer shield only, then I'll leave it up to you as to whether to keep it or get rid of it.
  8. #8
    Join Date
    Dec 2010
    Posts
    1,665
    SW VA
    Default
    Quote Originally Posted by mjncad View Post
    You would be surprised the things you can wrap around a drive shaft without a guard of some sort. Hay, baler twine and old fence wire come to mind. A Leatherman tool has saved my butt from walking home before.
    That reminds me, one time I ran over a metal slinky with my truck. If I didn't have my fence pliers with me I'd still be on the side of the road! Do you have any idea how long those dang things are?
  9. #9
    Join Date
    May 2009
    Posts
    628
    South Mississippi
    Default
    Definitely planning to correct/repair the guard. Just want to make sure I make a good decision on how it is repaired. I plan to have this tractor a long time and don't want to rig it. I want it to remain as close to like new as possible.
  10. #10
    Join Date
    Aug 2006
    Posts
    5,114
    DT86, good points that I failed to consider. One year I found numerous trampoline springs in the yard because some inDUHvidual neighbor didn't anchor their tramp, and a wind storm blew the dam thing to who knows where.
Similar Threads
  1. MT20D Front Drive Shaft
    By molallaretreat in forum Mitsubishi/Satoh
    Last Post: 04-28-2012, 11:22 AM
  2. Front Drive Shaft
    By wbvs58 in forum Kubota Owning/Operating
    Last Post: 04-20-2012, 04:12 AM
  3. Mowing Bx2350 front drive shaft
    By Mrh51072 in forum Kubota Owning/Operating
    Last Post: 03-19-2012, 05:47 PM
  4. Front drive shaft problems
    By Tdog in forum Kubota Owning/Operating
    Last Post: 07-31-2008, 10:29 PM
  5. BX front drive shaft
    By ericbx1500 in forum Kubota Owning/Operating
    Last Post: 04-28-2007, 09:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
