Page 5 of 10 FirstFirst ... 2345678 ... LastLast
Results 41 to 50 of 91
  1. #41
    Platinum Member Edward. S's Avatar
    Join Date
    Nov 2009
    Posts
    844
    Somewhere
    John Deere
    Default Re: Can a 5058M push over mature yellow pines?
    Quote Originally Posted by Don87 View Post
    A hand saw will work fine on saplings.
    I do have one of those :P .
    Quote Originally Posted by Zebrafive View Post
    If you have long enough chains that they will not hit your tractor, chain up and pull. I'll bet you can pull several at a time.
    If you are worried about them hitting your tractor, cut them off several foot above ground level then hook the chain to them and pull them out!
    I might use a fel to pull them out because I do have long chains, but I need like 60' of chain...
  2. #42
    Super Member AKfish's Avatar
    Join Date
    Oct 2004
    Posts
    5,402
    Alaska
    JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
    10' - 15' saplings? You should be able to root 'em right up with your grapple! I can't tell you how many small trees I've ripped out of the ground with the FEL grapple on my 110! Start about a foot or so back from the trunk with the root tines and curl, curl and curl some more until the whole enchilada is balled up and the top of the trees are laying on the ground.
    You're gonna end up with a dirty root wad... I clamp the trees along the trunk line with the wad hanging off to one side of the grapple and shake. Or let 'em sit in the rain for a few weeks and after a dry spell - shake 'em again.
    AKfish
    "Most people want to live on top of the mountain, but all the happiness and growth occurs while you're climbing it."
  3. #43
    Veteran Member pclausen's Avatar
    Join Date
    May 2008
    Posts
    1,442
    Nelson County, VA
    JD 5085M, Ford 1700, JD GT235, JD LT166
    I started a thread in the Projects section for the house construction, but figured I'd post a few action pics here as well.
    Collecting cut logs and adding them to the main pile:
    Getting ready to skid out a bunch of felled trees:
    Here's one pulled up to the main pile:
    Lifting it up onto the stack. I really need to get my rears filled. Had it not been for the fact that I'm loading facing uphill, I would have tipped forward (I still did a little bit raising the largest trees onto the pile)
    Boy that's a lot of logs!
    I'm thinking about finding someone with a logging truck to haul it the 10 miles to the mill instead of me doing it 7 tons at a time with my goose-neck and 3500. I found one guy that will do it for $200 per load. I figure an empty logging truck tips the scale at around 25,000 lbs and is around 100,000 lbs loaded real tight. So that's 75,000 lbs of timber per trip, or 38 tons, which @ $38/ton comes to $1,444. So he can do in one trip what it would take me 5 trips to do, which at his rate would be $40 per trip. Seems like a fair deal even though the mill is only 10 miles away. The catch is that it will be very hard for him to make the 1st turn getting out, from one private street to the other. Also, the neighbors will likely complain about a ~100,000 lbs truck tearing up the blacktop that they paid to put down.
    The perfect compromise would be to find someone with a straight logging truck that can do 40,000 lbs per load @ $100 a load.
    I would not be able to load anything but my own goose-neck trailer with my tractor, but the Case operator said he would be happy to load up a logging truck using the excavator (the way he operates, it wouldn't take him long at all).
    JD 5085M w/ H260 MSL Loader, Frontier AV20G Grapple, Frontier AP13G Pallet Forks, Woods SG100 Stump Grinder, Woods RM990 Finish Mower, Woods RB850 3 Way Hydraulic Blade, Woods LR108-2 Rake, Bush Hog 3209 Cutter, Vermeer 906 Chipper, Valby SGR76 3pt Grapple, Shaver 601H Post Digger, Tufline 8' Disc Harrow, Vicon Vari-Spreader MK-II 400, JD 45 16-3 Bottom Plow
    2002 Silverado Duramax 3500 Crew Cab LT 4x4
    BigTex 22.5K 25' Gooseneck Trailer
  4. #44
    Join Date
    Nov 2009
    Posts
    844
    Somewhere
    John Deere
    Quote Originally Posted by AKfish View Post
    AKfish
    I was asking about the saplings haha it was about trees so I asked here
    I don't have a grapple... I only have 4 Valve loaders not 6 valves. I did pick up another tractor though, a 6430 Premium + 673 Loader, 1400 Hours + or -. Worked on golf courses and loaded sand with a tiny bucket. it will have new tires 520/R38's and 480/R24's I think they are Michelins. So I thought it had a easy life. Has a 24 speed, refrigerator , automatic temperature control, air seat, non electronic loader joystick . I like the mechanical lever more cause it the electronic ones can't shift gears on the Autoquad to change gears. I got it for around 68k
    The problem is that the trees are far back with only a 7ft gap between a building and a greenhouse. I can get it at either side but one side is tight and dry, and one side is really wet.
  5. #45
    Super Member
    Join Date
    Apr 2004
    Posts
    6,750
    East Coast of Lake Huron
    Deere, several
    Let us know how much more it costs to repair the paint, dents and broken glass. Than just calling in somebody with a dozed or a articulated industrial loader.
  6. #46
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    28,335
    Branson, Mo.
    Kioti DK35se Hydrostat
    Quote Originally Posted by Edward. S View Post
    I have some 10' - 15' saplings growing by my building, best way to get them down? I want roots and the tree gone. Need some ideas, not wanting to rent anything.
    log chain works well. just wrap it around the tree 3 or 4 times and hook it. pull with drawbar. Or you can safely push 10 or 15 foot tall small saplings if they are alive. Never push anything with dead branches unless you want them on your hood or head. I have pulled over lots of 30 to 40 foot trees, just hook the chain up as high as you can reach, and then add 2 more 20 foot chains. Make sure when the tree falls you have plenty of safety margin in case you have mis-estimated the height of the tree.. you don't need the branches down on your head.
    James K0UA
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN . Igitur qui desiderat pacem praeparet bellum
  7. #47
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,839
    South West MI
    John Deere 2030, John Deere 6415
    Quote Originally Posted by pclausen View Post
    Thanks for the pictures. Love seeing your pictures! In the first picture looks like your front tires are squatted down a little, how much do you think you are lifting?
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  8. #48
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,961
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    I don't have a rotary cutter or saw. Hahaha. . Can I just use a chain and pull them up? Or drag them out? Their not very thick. Or spray gramoxone on them so it kills the plant cells and dies and browns up and rip them out.
    Before I got my backhoe, I pulled up by the root a couple hundred small saplings up to 25 feet tall and 4" in diameter using a chain and my tractor. Smaller ones, I used my RTV 900 and chains as it was much easier to get in and out of and get to the trees. Amazing what that little UTV would pull. IF you don't have either of those, a pickup truck with a strong bumper and long chain will work. Just hook the chain about 12-18" above the ground so it bends and pulls on the whole trunk. It works better if the ground is wet as the roots come out better, but you also have a bit less traction.
    I had this big area by a creek that was thick as hair on a dogs back with sweetgum saplings and medium sized trees. I got a lot of them with my tractor and bush hog, some up to 1" with a weedeater with a saw blade, some with a chainsaw but the kept coming back by sprouting from the roots. When I used the backhoe and dug up roots and all, it is pretty well free of sprout back now.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #49
    Join Date
    Jun 2008
    Posts
    10,961
    Bismarck Arkansas
    Can a 5058M push over mature yellow pines?-img_1164-jpgCan a 5058M push over mature yellow pines?-img_1165-jpg
    This is how it looks after removing hundreds of small to medium sized sweet gums over a two or three year period. Finally finished it up without sweating too much with the back hoe. It is hard work dragging a chain back and forth 40 feet for each tree in 100F temps or 30F temps., chainsawing and dragging brush by hand to clear from the thicket, but with the backhoe and hydraulic thumb, in less than a day, it put the remaining trees on the ground and in a pile and never left the TLB. MAN WHY DID I WAIT SO DARNED LONG TO BUY THAT THING.
    edit: The area in the first photo where leaves are on the ground by the fence is about all that was open when I bought the place, the rest was thick with sweet gum trees from 12" large to 1/4" small and constantly coming up from the sweetgum balls and root sprouts. By clearing it out, I lost my doe deer that raised a fawn there every year, but it sure looks better now. I can even see the back pasture across the creek
    Edit: in the first photo where leaves are by the fence is about all that was open when I got the place> The rest was overgrown with 1/4" to 12" diameter saplings to medium sized sweet gum trees so thick that you couldn't walk thru them. I can now see my back pasture thru the trees. NO Deer habitat now but then again, I don't have that doe eating on my fruit trees either.
  10. #50
    Gold Member JordanFTW's Avatar
    Join Date
    Oct 2011
    Posts
    320
    Southern Maryland
    Deer 110 TLB, 4300, LT180, LT160, NH LS185.B
    Might just be time to upgrade to a tandem dually trailer.
Similar Threads
  1. Replies: 5
    Last Post: 01-27-2013, 09:34 PM
  2. Smashed GN trailer into back of my 5058M :(
    By pclausen in forum John Deere Owning/Operating
    Last Post: 11-23-2012, 12:06 PM
  3. Using a box blade on mature grass
    By bxowner in forum John Deere Owning/Operating
    Last Post: 09-22-2011, 01:25 PM
  4. Thinning out pines
    By TNTractor1 in forum Rural Living
    Last Post: 08-12-2011, 06:55 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
