Verticaltrx
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
I started to install the intake preheater on my fathers 5045e today and have ran into some trouble with the wiring/instructions. The kit I got was the right part number for the 5045e, but it was an older kit and the instruction booklet was printed before the 5e series came out (it is also very unclear as to which wiring is used for which model.) I got the heating element installed, but am having trouble getting the relay hooked up and working. There is a green and a black wire with connectors that you are supposed to hook to the relay to activate it and I assume these are coming from the key. However, when you turn the key to the preheat spot there is no juice on either wire. Do I need to get into the harness somewhere else and hook up those wires to something? Am I doing it all wrong and a newer version of the manual would tell me to wire it differently? Any help would be appreciated, with the temps we are going to be having this tractor simply will not start without it. Thanks in advance.
