Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Join Date
    Nov 2012
    Posts
    1,545
    mansfield,Il
    john deere
    Default Re: Now Power in "C" hydro for 3120
    Is C the high range ? Yes it is going tobe (sluggish ) . You knew guys with knew tractors need a sticky ?
  2. #12
    New Member
    Join Date
    Jan 2013
    Posts
    5
    Dewey, Arizona
    John Deere 3120
    I solved the problem, but don't understand 'knew' and 'sticky'. And of course C is the high gear.
  3. #13
    Join Date
    Jul 2012
    Posts
    1,126
    Southeast Minnesota
    JD 4720, JD X748SE, JD 997, Farmall "B"
    Quote Originally Posted by AWG View Post
    What did you do to solve the problem?
    One thing you will find on this forum, is that you will get allot of confrontational post that add nothing to the subject matter. Just ignor it, and separate the "wheat from the chaff".
  4. #14
    Join Date
    May 2009
    Posts
    927
    South Mississippi
    2008 John Deere 5303 MFWD
    Default
    Quote Originally Posted by arlen4720 View Post
    Curious myself as to what the problem was. Sounded like a legitimate issue not related to length of ownership.
  5. #15
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Agree, lots of BS on this forum lately ignore it. Would also like to know what the solution was.
Similar Threads
  1. safe engine rpm "window" difference gear vs hydro
    By madmax12 in forum Owning/Operating
    Last Post: 08-30-2012, 11:22 AM
  2. 3120 Sediment Bowl "spring" or "stem" on filter??
    By OzGrasshopper in forum John Deere Owning/Operating
    Last Post: 12-28-2010, 07:56 PM
  3. Oil & Fuel 2520 Hydro oil change - is this "stuff" normal
    By hemiguy in forum John Deere Owning/Operating
    Last Post: 05-10-2008, 09:44 PM
  4. "Priority valve" Vs. "Power Beyond"
    By jimmer2880 in forum Hydraulics
    Last Post: 11-12-2007, 03:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
